Paint Shop
Clear Coat?
I have something that I need to Clear coat and what it to be glossy. I am not sure if the surface...
this thread has 2 replies and has been viewed 610 times
Old 06-06-2002, 06:07 PM
Ron
Default Clear Coat?
I have something that I need to Clear coat and what it to be glossy. I am not sure if the surface that I am going to put it on is enamal or laquer. Any suggestion as to what to use?? I would also prefer to buy it in an aerosal can.
Thanks Ron
Old 06-07-2002, 06:29 PM
David M. Lyon
Default Re: Clear Coat?
I have never had much luck trying to spray clear over ANYTHING that has already been painted and cured for a while, It just doesn't stay very long because it can't bind to the color coat. You can't sand the color because the sand scratches will eventually show, I would try to soften the base with some 3919s DuPont just before spraying on the clear enamel. I really recomend you experiment on another piece, or on the underside of whatever you are going to spray before you accidently ruin the finish. Usually with a basecoat/clearcoat system, you spray the clear on top of the color as a finish coat and they cure and bind together. .....Just some of my observations.... I'm afraid it's not much help!
David M.
Old 06-09-2002, 10:43 PM
DAVID M. LYON
Default CORRECTION !
Not 3919.....should have said 3812S enamel reducer.....Sorry about that.
David M.
Clear grease? Can you use it? Tom Geier Antique Gas Engine Discussion 16 05-07-2007 12:50 PM
fresh paint & clear coat SKocher Antique Gas Engine Discussion 6 07-20-2006 11:52 PM
Polished brass:To coat or not to coat? Lou Quirch Antique Gas Engine Discussion 5 01-03-2005 08:11 PM
Clear coat John Bunting Paint Shop 1 01-26-2004 06:00 PM
Very clear subject and name Ed Antique Engine Archives 4 05-10-2002 03:35 PM
