Paint Shop
Brown Stover?
I have a Stover 8 hp KD with 8 25 cast into the hopper. This engine is light brown and no amount of...
this thread has 1 replies and has been viewed 504 times
Old 10-10-2002, 10:31 AM
smootz
Default Brown Stover?
I have a Stover 8 hp KD with 8 25 cast into the hopper. This engine is light brown and no amount of scraping or removing parts has shown evidence of any other color. Is it possible that it is really supposed to be brown? Also I have problems with the spark plug "sooting up" after an hour or 2 of running. I am using a Champion W89D. The engine has a fuel pump and an overflow carb. EK Mag with Type 1 trip. Compression and valves seem good and ign timing is at about 5 deg BIDC. I have to run at about 1/2 choke all the time. This engine is running slower than it's recommended 450 rpm for show purposes but not "super slow" like I have seen others at shows. This is the first "larger" engine I have owned and I have timed the ignition and valves similar to my little Economy. That was good enough to start it but I could use some coaching to get it running better. Thanks for any help or suggestions. SCOTT smootz@zoomnet.net
Old 10-30-2002, 12:06 AM
Doug Wilson
Default Re: Brown Stover?
When you run them slower , they tend to soot up. Go to a hotter plug. Doug.
990 David Brown Sharon & Jamie Antique Tractor Talk 5 10-14-2009 12:13 AM
Joe Brown [Cushman Man] Dale Russell Antique Gas Engine Discussion 1 10-12-2007 01:16 AM
E.C. Brown Engine? JKWidener Antique Gas Engine Discussion 3 10-03-2007 08:23 PM
Brown & Cochran Bruce Flatmoe Antique Gas Engine Discussion 5 10-26-2006 12:32 AM
Brown Co. (IN) Swap Jim Thistle Antique Engine Archives 1 10-12-2003 12:36 PM
