Phosphoric Acid and HoppersWhat's the consensus here on using phosphoric acid in water hoppers to control rust? I have a...this thread has 2 replies and has been viewed 635 times
I have a galvanized water tank with mild surface rust inside. Will the acid harm the zinc? Or, will it neutralize the rust and add life to the container? Same question applies to cast iron hoppers.
Don't put phosphoric acid in a galvanized water container! You won't have the galvanize very long.
Phosphoric acid may remove rust, but it attacks the base metal, too. Leave it on too long and you'll find out. Generally speaking, metal is protected from corrosion with an alkaline pH. If you want to protect your metal from corrosion, throw in a teaspoon full of TSP, tri-sodium phosphate. |
Phosphoric acid + Galvanized = exothermic reaction as the zink is disolved into the acid. Only a certain amount of the zink can be disolved, but I wouldn't do it. Instead, I'd throw about 12 tea bags into the hopper full of water, and let it set for a while. The tannic acid in the tea will accomplish about the same rust conversion, it's just a different process. Stirr occasionally, do not add sugar, and serve to people you don't really like.
| Phosphoric acid ? | Chris Hibshman | Antique Gas Engine Discussion | 6 | 09-09-2007 07:58 AM |
| Phosphoric acid | Pacrat | Paint Shop | 1 | 11-14-2006 02:31 PM |
| Pictures of Phosphoric Acid De-Rust on my Stover | Paul Maples | Antique Gas Engine Discussion | 7 | 11-13-2006 11:32 PM |
| Anyone ever use Phosphoric Acid to DeRust | Paul Maples | Antique Gas Engine Discussion | 14 | 11-11-2006 04:11 PM |
| Put Antifreeze in your Hoppers! | Paul Spence | Antique Engine Archives | 9 | 11-14-2004 01:14 AM |
