Paint Shop
Rattle-can paint foaming
I've been battling a frustrating problem while spraying some small items with rattle-can black. In...
this thread has 2 replies and has been viewed 453 times
Old 05-02-2003, 09:52 PM
Orrin Iseminger
Default Rattle-can paint foaming
I've been battling a frustrating problem while spraying some small items with rattle-can black. In some areas the paint forms little bubbles, making it impossible to produce a smooth finish.
The parts were primed with lacquer-based red oxide primer and wet sanded. The "boiling" only shows up in small areas. Does anyone know what the problem might be?
I used this same brand of paint on bare sand-blasted metal and the results were satisfactory. I'm wondering if there could be either an incompatibility problem; or, perhaps there's a bit of sanding "dust" that's the problem. (Although, I thought I rinsed off the part and dried it.)
TIA for your help.
Orrin
Old 05-02-2003, 10:00 PM
Default Re: Rattle-can paint foaming
I have found over the years that mixing laquer based paints and enamel based paints can lead to disaster. One can go over the other, but not under. Don't ask me which way this goes because I can never keep it straight. The safe way is to use the same brand of primer as topcoat.
Lately, I've chosen NOT to use a primer coat. If you get a scratch, the primer shows through loud and clear. Instead of primer, I use the phosphoric acid treatment or if that's not appropriate, I bead blast lightly and spray top coat in several layers. Clean is the word!
Bead blasting works excellently when you want to paint galvanized pipe too.
-- Harry
Old 05-03-2003, 03:52 AM
Franz
Harry, in case you haven't heard, bead blasting has been obsoleted by Dry Ice Blasting. Now, if only I can get a second and third mortgage on the hovel, I can afford the machine, and really do some interesting blasting. The best part, no abrasive to clean up afterwards.
Forum Link (Paint Shop) If you are interested in OLD paint - Don't Miss This! Harry Antique Gas Engine Discussion 0 03-14-2008 10:27 AM
Forum Link (Paint Shop) If you are interested in OLD paint - Don't Miss This! Harry Stationary Steam & Traction Engines 0 03-14-2008 10:27 AM
Stover CT2. to paint or not to paint guyver11469 Antique Gas Engine Discussion 3 10-20-2007 01:04 AM
New Gas Tank to Paint or Not to Paint!? eagleeyelee65 Antique Gas Engine Discussion 2 01-11-2007 09:40 AM
Cushman Bean Special Rattle Can Color Machineryman Antique Gas Engine Discussion 0 08-01-2006 01:14 PM
