Boiled/Raw Linseed oilI've acquired (by accident) some raw Linseed oil! Can it be used as is on wood or can it be boiled...this thread has 4 replies and has been viewed 697 times
I've acquired (by accident) some raw Linseed oil! Can it be used as is on wood or can it be boiled (is that dangerous) to get the better product? Thanks Vic
Vic, Don't use it raw ... it will never dry. Don't know about boiling it.
thanks doug sorry i took so long i'd forgotten i posted here and dont come here often vic
Vic, "Boiled" linseed is not actually boiled with heat as you might think. It is a chemical process that changes the oil so that it dries more readily. Do NOT attempt heating it...you'll end up with a gooey mess...if it doesn't explode first! Check on the internet for info under oil based paints. Best, George
Raw linseed oil can be converted to "boiled" Linseed oil by adding a "Japaning" (it is still available). The available Japaning contains "Phoenix Salts" that will cause/allow the raw linseed oil to polymerize and harden.
A good thing to add too if you thin the boiled linseed oil with mineral spirits, or other solvents. |
| Boiled Linseed Oil and Mineral Spirts | Snitz | Antique Gas Engine Discussion | 11 | 10-17-2006 11:57 AM |
| Linseed Oil Finish | midpw | Antique Gas Engine Discussion | 4 | 03-26-2006 11:38 AM |
| Linseed Oil | Byron Roberts | Trucks, Trailers and Hauling for Shows | 0 | 07-04-2005 06:48 PM |
| Boiled Linseed Oil on old engines | BobRR | Paint Shop | 22 | 02-06-2005 03:46 PM |
| skids/linseed oil | Eric McKenna | Antique Engine Archives | 3 | 01-19-2002 09:08 PM |
