Paint Shop
What Primer on a Carb.?
I painted the carb on my 8N Ford Tractor about 6 weeks ago. Primed it first with regular grey metal...
this thread has 6 replies and has been viewed 940 times
Old 06-07-2003, 04:45 PM
Bob Camicia
Default What Primer on a Carb.?
I painted the carb on my 8N Ford Tractor about 6 weeks ago. Primed it first with regular grey metal primer (Rutoleum0 in a rattle can, then next day painted with New Holland Ford Red, and then waited for a day and put the carb in the wife's oven for 4 hours at about 150 degrees. All looked good for a week or so. Then the paint started to lift away like gas was getting into the primer and releasing it from the metal.
What did I do wrong, and how should I paint a carb so it doesn't have paint "run" or "lift?"
Bob
Old 06-07-2003, 05:51 PM
Default Re: What Primer on a Carb.?
If all else fails, blast it clean and dip it in phosphoric acid. Followed up with that 150 degree heat it should be pickled with a nice gray metallic finish.
Carbs and fuel tanks have to be the worst place for paint to hold up and it might be it was the primer that failed. I've had good luck with painting over top of the phosphoric treatment. No primer colors to show through when a scratch or abrasion comes along.
Old 06-07-2003, 08:04 PM
Bob Camicia
Thanks Harry for reply, but where does one look for the acid? A paint shop? or????
Bob
Old 06-08-2003, 12:30 AM
I get mine at Home Depot. An automobile paint distributor should also have it.
Do a SEARCH here on PaintShop for "phosphoric acid" and you'll find other posts.
http://www.enginads.com/paintshop.cgi/read/37107
Old 06-08-2003, 01:40 PM
Kid Dynamo
Other names of phosphoric acid products include: Ospho, MetalPrep, MetalEtch, Docspho, etc.
For those learning about Ospho, look at the ingredient list on Pepsi and Coke. Included ingredient is phosphoric acid.
Old 06-08-2003, 10:43 PM
Jeff Conner
I don't think it is the primer. I suspect you have a small fuel leak. Gasoline will lift most any fresh paint, baked or not. The only one it doesn't seem to bother is the two part urethanes, but they are expensive. I have also had good luck coating frequently fuel wetted areas with aerosol clear shellac after painting. Shellac is not soluble in petroleum base solvents. This only helps if gasoline drips on the area. If it is leaking at a joint, it tends to get under the paint where the paint ends. Also, keep your carb paint thin with just one or two coats at most after priming or phosphatizing. Be careful using heavy strength phosphoric acid on any zinc or pot metal parts.
Old 06-09-2003, 11:15 PM
Bob Camicia
Default Re: What Primer on a Carb.? Thanks For responses
Thanks everyone for the help.
Bob
Alamo primer cup? Jebaroni Antique Gas Engine Discussion 0 05-31-2005 12:43 PM
Best Primer to use Josh Downard Paint Shop 2 11-15-2004 05:14 PM
To Primer or Not ??? dusty Paint Shop 2 10-17-2003 07:02 PM
Primer gas Dave Valentine Antique Engine Archives 7 09-13-2002 01:18 AM
Primer cup Richard Smith Antique Engine Archives 0 09-15-1999 07:50 PM
