Steam Engines
Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Stationary Steam & Traction Engines
Stationary Steam & Traction Engines Antique steam engines, traction engines, their boilers and the related things that make them run.
need governor help
i deed to remove the spring material from the governor ball's.how do i do this?
this thread has 2 replies and has been viewed 835 times
Old 11-04-2002, 07:41 PM
Tex S. Holliday
Default need governor help
Old 11-04-2002, 07:54 PM
Andrew New
Default Re: need governor help
If it is a Pickering governor, the balls are made in two halves with a stud connecting them in the center. It's kind of tricky, but all that needs to be done is to unscrew the outer halves of the balls. Hope this helps you out!
Old 11-04-2002, 11:58 PM
Paul Woodworth
Tex If you have a Gardner Governor the Balls are held on by babbit. Send them to me, I have the Jig to hold them straight. Paul
Governor set up ? pnora Onan Generators 1 10-18-2006 10:03 PM
Oil Governor/Steam Governor Ed Bertschy Stationary Steam & Traction Engines 2 02-28-2003 09:35 AM
F&J governor Steve Gerot Antique Engine Archives 4 06-27-2002 09:16 PM
governor mike Antique Engine Archives 3 06-03-2001 12:49 AM
