| Stationary Steam & Traction Engines Antique steam engines, traction engines, their boilers and the related things that make them run. |
need info.what is the excepted tolerance for the cylinder to be out of round or taper on a steam engine...this thread has 1 replies and has been viewed 671 times
what is the excepted tolerance for the cylinder to be out of round or taper on a steam engine cylinder
Whenever I rebuild an engine, after the piston is removed, the cylinder is cleaned with a solvent and visual checked. Sometimes it needs to be given a quick runthrough with a hone to clean it up. The cylinder is then checked for taper, pitting, gouging etc., and if its more than 20-30 thou'out it would be rebored. If there is any question, I would rebore anyway.
