Steam Engines
Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Stationary Steam & Traction Engines
Stationary Steam & Traction Engines Antique steam engines, traction engines, their boilers and the related things that make them run.
Frick portable steam engine
I looked over a Frick portable today, about a 40 HP. The engine was being used to run a shingle...
this thread has 2 replies and has been viewed 2114 times
Old 05-24-2003, 08:48 PM
Brian Ferrence
Default Frick portable steam engine
I looked over a Frick portable today, about a 40 HP. The engine was being used to run a shingle mill and cord wood saw up until about 4 yrs. ago. It has been under cover and looks well maintained. The engine itself seemed to be in great condition and was very complete, all the plumbing and accessories were still in place. The boiler seemed sound, but some of the tubes may need replacing. A bigger concern was the stay bolts. A few of them were rusted down to half original diameter and would need replacing I imagine. Questions I have which some of you may be able to help with: I live in eastern Pennsylvania, where is the nearest shop who could replace the stay bolts? How much would that cost (I'm sure it isn't cheap)? What would a fair price be to offer for this engine? Any other words of wisdom or advice would be appreciated.
Old 05-24-2003, 10:41 PM
Little John
Default Re: Frick portable steam engine
If you are in sSouthe eatern PA give the boys at Rough & Tumble a call. They'll be able to give you a rough idea what is needed. The people at Strasburg RR can and do build entire new boilers for outside people, they may do repairs as well, but their expertise doesn't come cheap.
Old 05-27-2003, 08:19 PM
Paul Long
Before you get involved, you need to check the thickness of the crown sheet with an ultra-sound thickness tester. If the stays are that worn, the sheets may be thin as well. Needing a boiler would make it scrap price if you're willing to invest 15,000 having a boiler fabricated. Paperwork showing previous inspections is a plus. PA now requires yearly thickness testing. A hydro-test will show leaking flues. What area of Eastern PA are you looking for someone to do the work? That's a big area.
Frick Portable help BannerBoy Stationary Steam & Traction Engines 17 05-25-2011 05:49 PM
Frick Portable At Auction John Roop Live Auctions of Engines, Tractors and Old Iron 5 07-29-2007 06:26 PM
Frick Portable LeeCox Stationary Steam & Traction Engines 4 09-04-2006 11:23 PM
FRICK STEAM ENGINE HELP Denny Foster Stationary Steam & Traction Engines 8 09-17-2004 09:21 PM
