Steam Whistle Valve Leak
this thread has 2 replies and has been viewed 2767 times
Old 08-09-2000, 11:48:17 AM
Tanner Remillard
Default Steam Whistle Valve Leak
I Just recently aquired a large Lunkenheimer steam whistle but the valve leaks pretty bad. I have a different whistle that leaked and I put a stronger spring in it but it still leaks through the valve somewhere. "> . Is There someway to stop the leak?
Old 08-09-2000, 05:11:44 PM
Russ Hughes
Default Re: Steam Whistle Valve Leak
Do you have any idea of how the valve is constructed? Some steam valves have a disk that seats against the valve body. Most safety valves have this sort of a valve seat. You have to disassemble the valve and lap the seat and disk much like doing an intake or exhaust valve. The difference is that these seats are usually, but not always flat and not tapered.
If the whistle was originally designed for steam service, the valve will more than likely have metalic seats as the steam will cut any soft material. It will also cut a metal seat too, but not as fast. Once a valve with metalic seats starts leaking, you will soon be able to observe little lines or gouges across the valve seat.
This is usually called "wire cutting" as it looks like someone drew a thin wire back and forth across the seat sawing a thin grove across it. These cuts have to be ground or lapped out. A diamond faced lap usually does a good job of re- seating such valves.
Old 08-09-2000, 05:12:44 PM
Ken Majeski
This is a common problem with old whistles. I usually take them apart and chuck the valve in the lathe and reface it and if the seat is not too bad seat the valve with a little valve grinding compound. It's the same as repairing any small engine valve. If the seat is really bad get it surfaced like a small engine valve. Good Luck
Kens old engine page
1-1/4" whistle valve source? Allen Steam Stationary Engines, Traction Engines, Steam Boats 4 08-01-2008 07:16:51 PM
Whistle Valve? Shawn Perkins Steam Stationary Engines, Traction Engines, Steam Boats 12 08-01-2008 03:14:59 PM
NOS Lunkenheimer Whistle valve question Randy Hart Steam Stationary Engines, Traction Engines, Steam Boats 3 03-26-2003 12:01:27 AM
Valve stem gas leak Chuck Ostrander Antique Engine Archives 1 01-07-2001 09:20:38 PM
Steam Whistle, Steam Whistles Alva Cunningham Antique Engine Archives 0 08-03-1999 12:40:33 AM
