Information WTD on DynamoLooking for information on a Dynamo built by Western Engine & Dynamo Co. Milwaukee, Wis. The tag...this thread has 1 replies and has been viewed 553 times
Looking for information on a Dynamo built by Western Engine & Dynamo Co. Milwaukee, Wis. The tag reads Dynamo # 743471 Volts 40, Speed 1900, and Amperes 20. Need to find diagram on the switchboard. How can I use this to power some lighting? Thanks, Joe Fidd
My books don't list your generating unit but it was surely used to charge a 32 volt battery. My Delco generators charge from 38 to 40 volts. The engine speed is higher than Delco but if the generator was wound for that speed it works just fine. Delco's run around 1200 to 1350 rpm. The unit should have a start switch on it some place and the 32 volt battery was normally used to run back through the generator and opperate as a starter. Some of those units had a air/gas mixing valve permanently fixed to run the engine at the opperating speed under the charging load. Most of the time if you run it without batteries attached, it will run too fast and do a little bouncing around. I would need a little more information before I could give accurate advise. If you could get me a picture I might be of some help.
| old dynamo | Marcel Peumans | Generators & Motors General Discussion | 1 | 04-15-2006 01:40 AM |
| Old dynamo | Mystic | Generators & Motors General Discussion | 3 | 03-22-2004 03:29 PM |
| Dynamo information requested | Denis | Generators & Motors General Discussion | 2 | 07-11-2003 06:49 PM |
| FBM dynamo | paul | Generators & Motors General Discussion | 2 | 10-04-2002 03:01 PM |
| Dynamo | Anderson Leveille | Generators & Motors General Discussion | 0 | 08-03-2002 03:52 PM |
