info needed
I have an Onan modle W3M upright 2 cyl. water-cooled gen. of the 40's vintage, does any-one know...
this thread has 1 replies and has been viewed 728 times
Closed Thread
Old 10-30-2000, 08:00 PM
Leon Hackett
Default info needed
I have an Onan modle W3M upright 2 cyl. water-cooled gen. of the 40's vintage, does any-one know how to time the mag? There arn't any timing marks on the gears.
Old 11-01-2000, 08:36 PM
Gus Simms
Default Re: info needed
Leon: this is copied directly from the manual for my W2C. No 1 piston must be at top of its comp. stoke and TC marks exactly in line, (TC marks on crankcase and flywheel). Set breaker points at .20 (.15 for Wico), turn mag in direction of normal rotation until impulse just trips with the distributor arm pointing to No. 1 tower. Install mag without turning gear. Turn engine slowly and note whether impulse trips when TC marks are in line. If not to far off correct by turning mag frame slightly, otherwise turn one tooth more or less.
Closed Thread
Info needed on 7.5 JB-AR werfymmot Onan Generators 3 08-07-2007 04:51 PM
Info needed Mpetty Stationary Steam & Traction Engines 2 02-08-2007 11:25 AM
Info on 20.0ES needed... WmBeyer Onan Generators 6 02-04-2006 01:39 PM
MAG INFO HELP NEEDED SONNY Antique Engine Archives 1 05-24-2004 11:53 PM
Info needed Pete Daniel Antique Engine Archives 1 09-17-2001 10:31 PM
