Hercules Engine Parts ???I'm located in Northern Alabama and am trying to locate parts source(s) for Hercules Model "WXC3"...this thread has 16 replies and has been viewed 2510 times
I'm located in Northern Alabama and am trying to locate parts source(s) for Hercules Model "WXC3" Engine (6 cyl. - 4 1/4" Bore) ... (powers an early/mid 40's(?) Military Light Plant) .... need re-build parts -- Piston Rings, Rod Bearings, Gaskets, Valve Springs, etc. .... Any Info. Appreciated ... Thank's -- Mike
The following addresses were not valid. mwilloug@tds.net |
Try www.kanter.com, if that doesn't work, try the mil-Veh.org board. if all else fails, do a search on Google for Hercules engine.
Hi Mike, I have a 1946 Diamond T with a Hercules model CBJXE 6 cyl flat head. I was able to get all my parts at my local NAPA dealer, std rings, .010 under rods and .010 under mains. All the gaskets too. The big problem was the main bearings, they had standard in stock but none .010 undersise, although the part number in the book was still good, we had to wait for Federal Mogul to build some.
Thank's Franz, no help at the "kanter" site ... will try the News Group tonite ..
Thank's to you too Alan, however, I work for NAPA Auto Parts and everything for this paticular Hercules Engine (WXC3) is obsolete with NAPA & our parts supliers .... Thank's to you both for replying .... As best as I can determine, the WXC series Herc's were produced by the original Hercules Motor Co. before the Co. went "under" in the early 30's. Then at the onset of the Second World War the engine design was "revived" with slight updates and produced for military use (mostly on Light Plants/Generators) by the "New" Hercules Motor Co. ... I can probably "piece together" a set of piston rings but desperately need new rod bearings (the originals were severely scorched when the previous owner decided to start the engine with diesel fuel in the crankcase to "clean 'er out", surprisingly the old main bearings and crankshaft are still "good as new") ... the oil pan gasket can probably be re-used with a little help from some silicon sealer but the old Head gasket is beyond salvation ... Any Help from anyone will be greatly appreciated !! A message you sent was not delivered due to the following reason: The following addresses were not valid. mwilloug@tds.net Final-Recipient: RFC822; mwilloug@tds.net Action: failed Status: 5.1.1 |
WANTED PARTS FOR HERCULES ENGINE WXC-3 AIR BRAKE COMPRESSOR GEAR DRIVEN GENERATOR FAN FUEL PUMP 4 SPEED TRANSMISSION AND DRIVE SHAFT FRONT PULLEY LEFT SIDE CARBURETOR CYLINDER HEAD FOR DUAL IGNITION IF YOU KNOW WHERE I MIGHT GET ANY OF THESE PARTS PLEASE LET ME KNOW, THIS IS FOR A 1933 PIERCE ARROW TRUCK THANKS ERNIE
JERRY BIRO
P.O. BOX 206 MARTINSBURG,OH 43037 740-745-1475 fax 740-745-2475 He is the king of hercules engine parts |
Bay Engine and Parts 1640 Evans Ave San Francisco, Ca 94124 415-826-7400
Tons of Hercules Parts in our Napa Auto Parts Store, Ask for hernaldo |
Call Hercules Engine Components 2770 south erie st. Massillon, Ohio 44646 330-830-2498. They just purchased all the rights and blue prints from Hercules and are manufacturing them now.
I have a trojan loader with the inline 6 herculese motor in it if any one has any info abot the trojan loader please contact me or were i will beable to get a head gasket
Its been a few years ago but I used to get parts for them from the industreal engine desk at Jasper Engines , Jasper Indiana. You had to talk to the Jasper location, the regional sales offices for their rebuilt auto engines didnt know anything about the industreal stuff.
Try M&M Surplus Sales 845-469-3597 I just got a head and intake gaskets Good luck.
In previous post about history of Hercules, there is some confusion of two different engine companies. Hercules Buggy Company built engines of the single cylinder open flywheel hit and miss style under the Hercules Engine Company name til the mid 1930's. They were bought out by Servel and switched over to making refrigeration components. Servel did apparently build some engines from spare parts about 1935. It is thought that these engines were all exported. Servel was bought out about 1946 by the former 2000 Washer Company which had changed it's name to Whirlpool and is still in business today making appliances. Their main reason for buying Servel was to get the refrigerator icemaker, which makes half moon cubes and is still the best refrigerator icemaker on the market today, as a number of appliance companys use or copy it. The second Hercules Motor Company built and still builds multicylinder engines for a wide range of applications, as posts in this thread shows. I am not aware of when they started and would be interested in any historical info on them, in particular did any cars use the Hercules engine?
M AND M SURPLUS SELLS HERCULES parts. They been buying hercules parts since ww2 . call 845 469 3597
I collect the single cylinder hercules engines made in Evansville,Indiana from 1914-1934. I have a web page dedicated to them. I get a lot of inquiries from people wanting information and parts from the Hercules Motor Company that was located in Canton, Ohio. They built the mult-cylinder industial engines and were in business until 1999. As I have learned of people selling parts for these multi-cylinder engines I have pasted this information at the web site shown below. As mentioned before the assists were purchased by another group and I understand that they are supporting the exhisting engines still in use. Keith
http://www.herculesengines.com/hercu...lescanton.html |
Hello Mike,I haven't been on this board very long,so please excuse any mistakes I am bound to make. You most likely have your Hercules engine parts by now. I had a surplus Lincoln 400 amp welder that was powered with a JXD Hercules. It was a sweet running engine but it sure loved the taste of gas. Water got down the exaust and messed up the valves. I had to pull the head to get the valves out,so I pulled the base and put rings and rod bearings in. The ones I took out had bronse or brass shells with babbit lining. I don't know if I can tell what size they are now,but will check and let you know, if you haven't found anything yet. At least they would probably be better than what you said your's looked like. If I couldn't find any I would sure use these. That has been several years ago and I can't remember what I replaced them with. My crankshaft was real good. If you still need them,let me know.... George Arthur Eadwards
Hello Mike,I have been off line for 4 days,and wanted to let you know in case you had responded and couldn't find me. I remember having trouble getting rings for the JXD 6 cyl. Hercules. I finally got a set, but 4 pistons with cast iron and two pistons with chrome top rings. Thats what I used and since I was doing a valve job and cleaning up the bore,It seemed right to do the ring job. I could have got by with just cleaning up and reusing everything. The engine was not worn bad at all, what I did turned out realy good. I have always wondered if the bronze bearing shells were original. I think I finally found Federal Mogul bearings. I'd like to know how you made out. Arthur Edwards
| Need Parts For Hercules IXBER Engine | M. Hadley | Generators & Motors General Discussion | 3 | 03-13-2007 10:10 PM |
| Parts of Hercules BXB | JBailey | Antique Gas Engine Discussion | 5 | 03-02-2007 12:36 AM |
| Hercules ZXB engine-Looking for parts | Unterein | Antique Gas Engine Discussion | 3 | 04-05-2006 10:52 PM |
| Hercules Parts | Dan Donaldson | Antique Engine Archives | 1 | 06-30-2004 05:02 PM |
| Hercules engine parts | m mitton | Generators & Motors General Discussion | 0 | 08-30-2002 01:26 AM |
