info on Universal gensetWould appreciate any help with any kind of info on a genset made by Universal Motor Co in Oshkosh...this thread has 1 replies and has been viewed 575 times
Universal Motor Co in Oshkosh Wisconson Mod 3000-A Plant31546 GenNo14103 volts110-125 DC FI amps 24 rpm 1450 watts cont 3000 watts inter 3750 It has a 2 cylinder water cooled engine that is crank started. It uses a Bosch mag and Schebler carb. Engine runs ok but gen doesnt put out power. The output wiring consists of 3 heavy gauge wires and 1 lighter gauge wire(purpose unknown). This is a DC set. I am usually working on AC sets at my job so I am somewhat lost on Dc sets. Also the oil dipstick is missing so any info as to its proper length would be a help. Thanks again for any help Shawn |
Shawn,
Some early 110 V plants charged and started with a 110 volt battery set, which would make the one of the heavy wires a series winding for starting. The lighter gauge wire should be for field resistance. The other two should be arm + and -. It will take some work with an Ohmeter to tell for sure. Universal made a two cyl. water cooled in the twenties. See the History of the Universal Motor Co. at this extra long address. www3.bc.sympatico.ca/Atomic_4_Eng_Service/index.htm |
| 30 kw hol-gar genset info | Ren W | Generators & Motors General Discussion | 0 | 11-08-2006 08:04 PM |
| Need Info For Genset 5ack | rapgar1 | Onan Generators | 2 | 06-01-2006 02:40 PM |
| Universal 2 cylinder info | Monty | Antique Tractors - Old Iron Lugs, Cleats and Tracks | 2 | 04-21-2005 01:50 AM |
| Universal Motor Co. GenSet | Rick Strobel | Generators & Motors General Discussion | 7 | 03-11-2005 06:50 PM |
| Need info Army genset | Fred Olsen | Generators & Motors General Discussion | 1 | 08-11-2004 09:32 PM |
