Questions on Lalley F
Hey, HAPPY THANKSGIVING everyone. Hope this posting finds each and everyone of you happy and healthy. Gus, hope your Western Electric turkey is delicious.
Now, I can never write a short posting so please bear with me and I do apoligize in advance for the length of this posting. I have a Lalley Model F that starts easily and runs great. I have three questions concerning its operaion. I have a Model HU Operator's Manual (thank you, Gus Simms) and use this as a guideline for my Model F. For a gas/oil mixture ratio the book says 5 gallons of clean gasoline to 1 pint of mineral oil. I use a mixture of 1 gallon gas to 1/2 pint of non-detergent oil (16/1). The engine does not smoke nor do the ball-bearings make any dryness noise. However, since the engine putts along at 1700 RPMs should I enrichen the mixture to 12/1 to give the bearings a little more lubrication. For 1 show last year I did use the 12/1 ratio and the engine did smoke (like a Maytag-no insult intended). If I am harming the bearings, piston rings, sleeve, etc. I will use the 12/1 ratio, but if the 16/1 mix is OK I would rather stay with that!! Question #2-In the governor resevoir the governor rotates in a level of oil. How much oil? Just enough to lubricate the governor shaft? Or 1"? Or 1/4 resevoir full? How much? On the Model HU, the book states, there is a resevoir glass oil guage to check the oil level which should be maintained about half way up on the glass, but, viewing the picture of the entire engine, I cannot tell at what height half way full is in relationship to the bottom of the resevoir. Because the Model F is designed differently in the governor and resevoir area I am uncertain as to how much oil the governor needs to "sling around". Question #3-Occasionally, on shut-down the engine will "fire" or pop with the Magneto points shorted-out. To shut-down the lightplant, I shut the tank gas off, wait 10-15 seconds, pull the mag. kill switch. From engine full speed to complete stop takes 30-35 seconds and during this time the piston is still taking in and exhausting fuel. I normally run 2 lightplants for 20 minutes, then rotate to 2 other lightplants, so this lightplant is started-up and shut-down once every 2 hours (unless someone wants to see it run on request). The engine "fires" or pops maybe 1 of every 3 shut-downs. During the 30-35 second shut-down it will "fire" about 10 seconds after the mag. kill switch is pulled for maybe 2 seconds, then about 5 seconds later for 2 seconds and then a third time 5 seconds later for a couple of seconds and then not fire anymore. I know it is igniting the fuel drawn from the carburetor, what do I do to stop this firing? I could shut the tank gas off and let the carburetor run dry, but I don't want to because of the way the engine "misses out" when running out of fuel. I tryed, prior to pulling the mag. kill switch, slowing the engine by holding the governor arm down but still got the popping on shut-down. The cylinder head is hot, but the cooling tank water steams very little during the 20 minute runs. I know the magneto is not bleeding "juice" to the spark plug because I pulled the plug wire off on several shut-downs and still had popping. This Lalley is the only high speed, 2-cycle lightplant I have so I have no other unit to compare it with for shut-down. Is this normal for a Lalley? Does this go back to fuel/oil ratio? Is the head possibly hot enough that it ignites the drawn gas? If so, why not throughout the complete shut-down? None of these questions are real earth-shattering, I just do not want to long-term damage the engine due to my ignorance in not asking questions. I would appreciate your help, suggestions and information on the above questions. Thank you in advance!!! I would like to find a reprint of a Model F manual, gladly paying for any copying, mailing and incurred costs. On another subject. Harry, THANK YOU, THANK YOU, THANK YOU!!! I wrote 6 or 8 weeks ago inquiring about other lightplant/generator collectors and never dreamed you were working on developing a new section devoted to lightplants/generators/electrical equipment and related. I. for one, am grateful beyond words for electrical "stuff" is my playtime passion!!
