Kohler Generators
Kohler 662 info needed
I have a Kohler gen. Mod # K662EP,Spec.# 33489b, Elec. plant Mod.# 7.5RMK62, Ser# 355183. I know...
this thread has 17 replies and has been viewed 3925 times
Old 11-29-2000, 12:16 AM
Chris Bailey
Default Kohler 662 info needed
I have a Kohler gen. Mod # K662EP,Spec.# 33489b, Elec. plant Mod.# 7.5RMK62, Ser# 355183. I know it's old but can't seem to find any info on it to find out how old it is or any value. The unit is complete and runs. Can anyone help? Thanks, In New Jersey.
Old 11-30-2000, 01:17 AM
Bill Garman
Default Re: Kohler 662
According to serial# list, it appears to be from 1972. I think that the K662 is 24HP. Kohler 662 parts are getting scarse, but Melroe at one time used the K662 in a Bobcat, and bought up a supply of parts. Melroe may have some parts in storage that can't be found anywhere else.
Old 04-28-2003, 11:06 PM
john busch
Default Re: Kohler 662 carburetor
Could use a rebuild kit for a 1965 kohler 662hs.Who sell them. Thank You
Old 08-21-2003, 12:34 AM
Dan Coley
Gentlemen, I have a 1966 bobcat m500. I bought it with the engine blown in two. With it I recieved a fresh stock bore block and a lot of nos parts. Home free right? NO WAY! The NY state kohler distributor could only find one stock bore piston. Nothing else. No seals, rings, bearings, nothing. Bobcat has since purged thier inventory of engine parts, also. So, having restored many other things, I just chased down the guys who ball up the inventory. One guy seemed decent but was suffering health problems and the other guy, well it would have cost $3000 to rebuild the k-662, So I gave up and re-powered with a robin-subaru for $1170. I still have the parts k-662 and I also have a parts k-660(babit only-no tapered roller)power plant engine.
Old 08-25-2003, 01:04 PM
Mark Briggs
I've recently inherited a k-662 on a generator. Unfortunately, the valves are toast, and the magneto is busted. But the pistons/bores look great. Any chance you'd be parting out your 662, and would have such parts available?
Mine's a 662EP, spec 33111B, with a Wico XH-2062E magneto.
Give me a holler if interested. markbg@nortelnetworks.com
Cheers, Mark.
Old 09-09-2003, 03:38 PM
Sid Ellis
Default Re: Kohler K-662
Have a complete, running Kohler K-662/7.5 KW Generator set for sale. Super original condition, always run on LP, low hours. Stored in CT. Email if interested.
Old 10-17-2005, 07:04 AM
John-K662 John-K662 is offline
I recently purchased a Melroe M500 Bobcat with a non-working engine. I am looking for parts, maybe an whole new engine OR anyone with experience replacing the engine with a newer type. Thanks in advance. I am in Oregon-jo-removethis-hn@mgballroom.com
john balwit
Old 11-10-2005, 10:42 PM
Talonman69 Talonman69 is offline
Hey guys,
I too was interested in either a rebuild kit for a K662 from a M500 Bobcat, or for any info in repowerig them. namely what brand motor, model, and tips on install.
email me at talonman69@comcast.net or post on here
Rob
Old 11-11-2005, 06:46 PM
Sid Ellis":
Please call me. I am interested in that K662 engine. 503 550 5642
Old 12-12-2005, 02:39 PM
orsche orsche is offline
Smile Re: Kohler 662
I have a Kohler Generator K662EP, Elec. plant Mod.# 7.5RMK62, Spec #33489b, Serial #336442.
It has been stored in a dry basement for around 20 years and definetely had minimal use and is very very clean.
I have not started it up. I do know that tt runs on Propane.
I was curious as to its age and value.
I have pictures for anyone interested. Please email me with questions.
Robert
Old 01-19-2006, 09:53 AM
kevconllc kevconllc is offline
Cheers, Mark.
Mark, would you be interested in selling the timing gear off your mag? Thanks, Kevin
Old 01-19-2006, 09:57 AM
I have some K662 parts!!! Kevin @ 502-638-2273 P.S. I also need some parts!
Old 01-28-2006, 09:08 PM
James Eberly James Eberly is offline
I have a 500 bobcat that needs an engine. Can you tell me how you repowered yours? James Eberly
Old 03-01-2007, 06:02 PM
mheadid mheadid is offline
do you still have the m 500 bobcat motor?
Old 03-04-2007, 03:17 PM
jason m jason m is offline
i am still looking for a 662 motor to, i am in mass on the CT/MA line. the other part i need is a clutch/tourqe convertor for my melroe model 500 skid steer, not sure what its called but it's the part that comes off the main shaft that the belt go's around. if you have an extra one e-mail me at brokenwillys@aol.com or if you find a motor for sale, thanks jason.
Old 05-09-2007, 10:00 AM
Jon Dorman Jon Dorman is offline
Hello. I have a few parts for sale for a K662. NOS stnd pistons/no rings, NOS cam shaft, NOS cam gear, & a complete working rockford clutch assembly. Possibly other used items.
Old 08-22-2007, 08:59 AM
Ducky Ducky is offline
looking for a cyl head if you have one ducklands@gmail.com
Old 04-22-2009, 09:45 AM
5jhammond 5jhammond is offline
Default Re: Kohler 662 info needed
I bought an engine that I think is a k662 the model tag is gone so I'm not sure. It runs perfect. I'm thinking about putting it in my jd 318 . I need to know if I should use it or if anyone out there needs it for a replacement engine like in a bobcat. I need to know what is the value of it .
Thanks,
Jerry
Kohler schematics needed djackman Kohler Generators 0 04-13-2007 10:47 AM
Kohler 161 fuel pump needed Kenn K Garden Tractors / Mowers / Scooters 0 11-29-2006 02:33 PM
HELP! Kohler 6.5CZ Block needed!! Fluffer Kohler Generators 7 07-11-2005 10:53 PM
Kohler 30R82 information needed mxpilot Kohler Generators 0 12-23-2003 11:44 PM
Kohler carb needed Joe Kohler Generators 1 06-07-2003 02:26 PM
