32VDelco plant
I have a 32v delco plant at home ade an a bit confused about it. I can't get it running. I huck up...
this thread has 1 replies and has been viewed 541 times
Old 12-01-2000, 11:34 AM
Corey Wey
Default 32VDelco plant
I have a 32v delco plant at home ade an a bit confused about it. I can't get it running. I huck up 3 12v batteries and I put a load on it but it won't run. any help would be greatly appreated. thank you. Corey
Old 12-02-2000, 08:40 AM
Gus Simms
Default Re: 32VDelco plant
Corey, first, make sure your batteries are hooked up in series(plus on the first to minus on the second Etc.)Second hook up to the battery + and - terminals on your plant. Lift the starting switch and your plant should go. If it doesn't check the brushes and armature, to see if they are reasonably clean and that they move easily in the brush holders. After that try to clean the contacts on the starting switch. If the gen. is good it should turn. Make sure you unhook the battery before you mess with any of the electrics.
G E LIGHT PLANT Ray Gardner Generators & Motors General Discussion 1 10-01-2004 10:01 AM
GE Light plant Ray Gardner Generators & Motors General Discussion 2 09-02-2004 09:04 AM
F-M light plant Don Generators & Motors General Discussion 0 03-27-2002 12:26 AM
Light Plant Don Generators & Motors General Discussion 0 02-13-2002 10:34 PM
WW2 Light plant Tom Jamboretz Onan Generators 0 01-13-2002 08:15 PM
