Delco 32 Volt Generator
I need a wiring diagram for this generator. Discription: Painted black. Has an electrical panel...
this thread has 7 replies and has been viewed 1188 times
Old 01-17-2001, 05:49 PM
Emmett Shaffer
Default Delco 32 Volt Generator
I need a wiring diagram for this generator. Discription: Painted black. Has an electrical panel that is attached to the top of the generator. I could also use an Operators Manual and a source of supply for the rod bearing. If any one has a picture of one I could match with what we've got, please post or send by e-mail to me. Thank you!
Old 01-18-2001, 12:09 AM
Don C. Wiley
Default Re: Delco 32 Volt Generator
Delco made around 70 different models of generator, and probably about half of them were painted black. If you have the capability to post a picture here, I think I could tell you what model you have and I might even have a manual I could copy and send you.
Good luck! "DELCO DON"
Old 01-18-2001, 12:13 PM
Emmett Shaffer
Don, Unfortunately the generator is torn apart. I will try to get photos and/or some numbers. I have the facilities to forward photos. What photos of parts would you need to best identify this generator? Thanks! Emmett
Old 01-18-2001, 04:06 PM
Emmett Shaffer
We found some numbers for the Delco generator. On the crankcase: on a tag, 58695 On the crankcase: cast-in, 6H or 9H depending on how you look at it. If this is any help, let me know. Thanks! Emmett
Old 01-19-2001, 12:23 AM
Don C. Wiley
If I had a picture of the flywheel with a ruler across it so I know what diameter it is and one of the control panel, that should narrow it down considerable.
The number 58695 on the tag should be the serial number and the 6H or 9H I don't know about them.
Some day (if I live long enough) I should have enough information to be able to date some of the most common Delcos by the serial number.
"DELCO DON"
Old 01-19-2001, 01:31 PM
Emmett Shaffer
Delco Don, I have a lead on a possible model number. Someone who has some knowledge of these generators suggested that it may be a: Model # 850 Hope this helps! Emmett
Old 01-20-2001, 01:10 AM
Don C. Wiley
Emmett, from the picture you sent me, that is for sure a Model 850 Delco light generator.
I saw one in Kansas that was painted the Delco reddish maroon color. I was told that if you sent your unit back to the factory to be rebuilt that they painted it the Delco "red".
"DELCO DON"
Old 01-20-2001, 11:18 AM
Emmett Shaffer
Don, But I did not send you a picture. I don't have any as yet. I hope to get some this weekend. Emmett
Delco points 32 volt Ronnie Dykstra Generators & Motors General Discussion 12 05-03-2009 12:35 PM
Need Help ON Wireing 32 volt Delco Donald A Smith Generators & Motors General Discussion 3 07-30-2007 12:53 AM
Old KW generator 6 Volt? Robt. Generators & Motors General Discussion 7 06-16-2005 04:10 AM
32 Volt Delco? Kent Redd Generators & Motors General Discussion 1 07-12-2004 04:47 PM
value of 32 volt delco Robert Rathgaber Generators & Motors General Discussion 0 10-28-2003 11:03 AM
