Kohler Generators
Info wanted on Bus generator
Several years ago I helped get a Flxible bus that was converted to a motohome back on the road. It...
this thread has 4 replies and has been viewed 590 times
Closed Thread
Old 01-28-2001, 11:48 PM
Bob Miller
Default Info wanted on Bus generator
Several years ago I helped get a Flxible bus that was converted to a motohome back on the road. It had a small 4 cylinder generator in a locker above the left rear wheel, and I was amazed of the small size. I believe that it was water cooled and the 4 cyl. engine was about 12 inches long, and had a generator attached to the rear of it. Does anyone know what it might have been, or know where information might be obtained? I like small engines. Thanks in advance. Bob
Old 01-29-2001, 03:41 AM
Russ Hughes
Default Re: Info wanted on Bus generator
How large was the generator? If it was water cooled, where was the radiator mounted? Was it an overhead valve engine? Did it have a built in crank on the opposite end from the generator?
Old 01-30-2001, 12:44 AM
Bob Miller
It was a flat head water cooled engine. I believe that it was supplied water by the bus cooling system. I do not remember a crank, but only saw it for a few minutes. I did not note the voltage or amp output.
Old 01-30-2001, 04:17 AM
Russ Hughes
I have no idea what the engine-generator might have been. There is nothing cuter than a little four cylinder engine of that size. I have a couple Kohler generators of that size, but they have overhead valves, weigh 500 pounds and they were rated at 1.5 kw 24 hours a day seven days a week. For a three horse engine they hold almost a couple gallons of oil in the crankcase sump.
Old 02-02-2001, 09:44 AM
Guy (GUS) Simms
Kohler made a lot of 2.5 to 5 kw flat head powered gensets. The block on the 3 kw mod. is about 14 inches long, a tad larger than the 4 cyl. ohv. Ther were also a lot of others, powered by various makes of engines like Continental & Hercules.
Closed Thread
Vespra generator info wanted Ken Meeks Generators & Motors General Discussion 0 08-03-2004 08:07 AM
INFO WANTED ON GAS TURBINE GENERATOR Denny Foster Antique Engine Archives 3 01-25-2004 11:44 PM
Old Generator wanted Ted Milson Generators & Motors General Discussion 2 12-02-2003 05:01 PM
WANTED-Generator E.C.Mims Generators & Motors General Discussion 2 12-21-2000 07:25 PM
Old B&S WMG generator wanted J.Wilkens Generators & Motors General Discussion 0 11-02-2000 10:33 PM
