Delco Model 8C3
I am new to the hobby (1 year/7 engines) and am going to purchase a Delco Model 8C3. I have several...
this thread has 1 replies and has been viewed 390 times
Old 01-30-2001, 01:49 AM
Bob Kelly
Default Delco Model 8C3
I am new to the hobby (1 year/7 engines) and am going to purchase a Delco Model 8C3. I have several questions and hope someone can help. First there are no batteries with this unit. What would be the best route to take to get 32 volts worth of batteries hooked in series? Cost is a factor as I have limited funds. Next, the light plant came with a copy of "Delco-Light Service Manual--Models 778and 786". Is this manual OK to use with my model 8C3? Third, has anyone created a list of "common" problems that are encountered when dealing with the relay panel and/or engine. Can I burn unleaded gas? Well that covers the high points. Hope someone can help. I'm really excited about the hobby and showed at all but one of our club's events last year--great fun. Thanks Harry for the site!
Best,
Bob Kelly--Lompoc, CA
Old 01-30-2001, 07:09 PM
Don C. Wiley
Default Re: Delco Model 8C3
Bob, my information indicates that the 8C-3 and the 778 and 786 are very similar. I would think you could use the 778/786 manual to do the standard maintenance. If you get into more in depth repair you will need more help. I assume yours has a control panel with (I think) five relays in it. There is a reverse current relay in there that probably is bad, and if it doesn't work your motor won't run or won't run right.
You have several options on the batteries. I have used three 12 volt lawn and garden batteries in series. The best is to use two 12 volt deep cycle and one 8 volt deep cycle.
I burn unleaded with 10% ethenol and mine have been running for several years at shows. Some of those generators had an A-C fuel pump on them and some did not. If you have a fuel pump the modern gas will disolve the diphram. You will need to change that. I have some material I got out of some old propane regulators and that seams to work alright.
If you need further help, e-mail me and I'll try to provide it.
"DELCO DON"
Delco 32Volt 800watt Model 8C3 Wink Generators & Motors General Discussion 4 02-09-2008 12:30 AM
Delco-Light model 600 Bruce Bailey Generators & Motors General Discussion 4 01-24-2007 06:22 PM
Delco-Don Gary Bahre Generators & Motors General Discussion 3 07-26-2004 10:24 PM
Delco model 600 Steve Wright Generators & Motors General Discussion 3 08-19-2002 04:47 PM
Delco Model B6 Bill Chason Generators & Motors General Discussion 0 11-14-2000 09:55 PM
