kohler infoI am looking at a kohler gen set that the tag says 8kw & 10 kwa. what is 10 kwa? Are there any...this thread has 1 replies and has been viewed 833 times
I am looking at a kohler gen set that the tag says 8kw & 10 kwa. what is 10 kwa? Are there any place where I could get some info on hooking up the low voltage side of this thing. It says 32v low which i am asuming that with 32v hooked up the dc side of the gen will act as a starter. I have two smaller kohlers that work this way.It has a 4cyl fc wakasha engine on it. The guy wants $500. for it is that resonable. thanks mike
The tag should say KVA (kilo volt amp). DC plants are rated in KW's (kilowatts)which is volts x amps x 1000, AC plants in KVA's, which is volts x amps x 1000, but for some reason, unbeknownst to me , it doesn't end up as watts. Did I mention that I'm a carpenter? $500 is a lot of money (a couple of weeks groceries and a tank of gas), but if the plant is nice and in good working order, you can't buy an 8 or 10 KWA plant for for that kind of money.
| Med-old Kohler 7.5 KW Info | K2 | Kohler Generators | 10 | 05-25-2007 01:33 AM |
| Kohler K info | Alan James | Kohler Generators | 1 | 05-18-2006 05:43 PM |
| Need Info on Kohler engine! | bspangler | Kohler Generators | 0 | 06-07-2005 11:09 AM |
| Kohler 5R61 Info | bspangler | Kohler Generators | 0 | 06-02-2005 12:31 PM |
| Kohler Info | Hank Czerwick | Kohler Generators | 1 | 04-14-2003 08:07 PM |
