Generators & Motors General Discussion Antique Generators, Light Plants and Old Electric Motors: Questions and answers about restoring and showing old power generation systems.
Edison Alkaline Batteries
I have a set of Edison Alkaline batteries that need the electrolyte replaced. I have an old...
this thread has 1 replies and has been viewed 1095 times
Old 06-13-2001, 01:35 PM
Patrick Traubert
Default Edison Alkaline Batteries
I have a set of Edison Alkaline batteries that need the electrolyte replaced. I have an old electrical engineers reference book that states the electrolyte is a 20% solution of Potassium Hydroxide (KOH) with a little Lithium Hydroxide (LiOH). Does anyone know if the 20% solution is by weight or some other measurement? It has been a while since I took a chemistry class.
Old 06-27-2001, 10:22 PM
Franz
Default Re: Edison Alkaline Batteries
It took a bit of digging, but according to International Textbook's 1939 book on batterys, the Edison Nickel Iron battery was supposed to be filled only with solution available from the Edison Factory. You have the chemicals correct, but nothing I have indicated the percentages, either by weight or volume. The best I can do is suggest you experiment with a hydrometer. According to the book, specific gravity of the solution in discharge condition should be 1.160 at 60 degrees farenheight. A fully charged cell should have a specific gravity of 1.230. The information is somewhat confusing as it also says the solution should be renewed if it drops to 1.160.
Edison Nickle Alkaline Storage Batteries mmcss Antique Gas Engine Discussion 12 05-27-2011 08:16 AM
Edison Batteries Mike Schweikert Generators & Motors General Discussion 2 10-16-2006 09:26 PM
Edison batteries Don C. Wiley Generators & Motors General Discussion 7 07-08-2003 05:48 AM
Electrolyte For Edison Alkaline Batteries Patrick Traubert Generators & Motors General Discussion 1 06-27-2003 12:22 AM
Edison Alkaline Storage Batteries... Michael Pawelek Antique Engine Archives 2 08-22-2000 10:21 PM
