Generators & Motors General Discussion Antique Generators, Light Plants and Old Electric Motors: Questions and answers about restoring and showing old power generation systems.
Blue Diamond Generator
lable shows..Gas-o-lectric ser# B11332 DD.110 VDC 110 SS.836 Watts 350 Rpm 2100 By the Gen-E-Motor...
this thread has 6 replies and has been viewed 2264 times
Old 09-03-2001, 08:11 PM
Randy Hart
Default Blue Diamond Generator
lable shows..Gas-o-lectric ser# B11332 DD.110 VDC 110 SS.836 Watts 350 Rpm 2100 By the Gen-E-Motor Corp. It's missing the rear cover of the Gen. and the brushes and cooling fins are exposed.. What kind of engine was used to power this ? It looks like a Reo with the slant cylinder and all, but no name on the engine at all ! I would consider trying to fix it up if I knew what brand of part's to look for ( Carb ) Anyone help a brother in the( DARK ) out ? Thank's Randy
Old 09-03-2001, 08:12 PM
Randy Hart
Default Re: Blue Diamond Generator
One thing I forgot.. Pioneer Gen-E-Motor Corp.
Old 09-03-2001, 09:39 PM
bill garman
Pioneer Gen-E-Motor, I think is now Pincore generators of Chicago IL.
Old 09-03-2001, 10:37 PM
Randy Hart
Default Re: Blue Diamond Generator/ another clue
It's a 4 cycle with the fuel tank located in the two wheeled cart it's mounted on..
Old 09-04-2001, 07:13 AM
Zira
Pincor has been out of business since the late '70s. There are a few parts floating around though (alas, not the ones I needed).
Old 09-12-2001, 08:56 PM
Gus Simms
Randy, the engine is a Johnson Iron Horse. I have a Pioneer Gen-E-Motor and a Johnson Iron Horse Generator, the engines are almost identical. The Iron Horse seems to be much newer. I found the Pioneer quite a while ago, and ID'd the engine from an article in Gas Engine Magazine.
Old 09-13-2001, 04:41 PM
Randy Hart
Default Re: Blue Diamond/ Thanks for all the help ! *NM*
Blue Diamond Generator Scott Wenrich Small Air Cooled Gasoline Engines 0 01-30-2007 05:09 PM
Old blue diamond gary tool and die Farm + Industrial Antiques and Collectibles 1 02-23-2006 03:26 PM
Blue Diamond generator Duane Kelley Generators & Motors General Discussion 6 11-17-2005 06:29 PM
Blue Diamond generator Jeff Conner Generators & Motors General Discussion 3 09-01-2004 07:19 PM
Blue Diamond Generator/Gas-o-lectric Plant Alan James Generators & Motors General Discussion 5 06-18-2003 02:14 AM
