Kohler Generators
Kohler Generator Question
I recently aquired a 1953 Kohler generator with a 24 volt electrical system. Were these units...
this thread has 6 replies and has been viewed 711 times
Closed Thread
Old 09-20-2001, 08:46 AM
largent63
Default Kohler Generator Question
I recently aquired a 1953 Kohler generator with a 24 volt electrical system. Were these units positive ground or negative ground? Both cables are the same color and I don't want to fry it on the first attempted start. Thanks in advance:
largent63
Old 09-20-2001, 11:46 PM
vogel electric
Default Re: Kohler Generator Question
Hi check the cables with a volt ohm meterto see which one is grounded. You should beable to see the one that runs to the houseing.
Have a nice day
Old 09-22-2001, 12:18 PM
largent63
The cable that is grounded to the frame is intuitively obvious. What I need to know is which battery cable goes to the generator frame! Thanks: largent63
Old 09-22-2001, 09:23 PM
Frank DeWitt
The short answer is I don't know, But I do have a 1926 and a 1948 Kohler and they are both - Ground
Frank
Old 09-22-2001, 11:05 PM
bill garman
Can't say for sure about yours, but every Kohler generator, or diagram that I have shows NEG. ground, with charging rate resistor going to POS.
Old 09-22-2001, 11:29 PM
largent63
Thanks for your responses Frank and Bill. When I got the generator from work it had been out of service for 20 some years. The batteries were long gone and there was nothing to base an educated guess on. Now I can hook it up with at least some level of confidence that I won't fry it. Thanks again:
largent63
Old 09-23-2001, 12:03 AM
Franz
If the battery leads still had battery clamps, the positive would be the larger diameter.
Closed Thread
Question about a Kohler gen jkloepping Kohler Generators 11 11-05-2006 05:54 PM
Kohler Generator question 7cm21rv Busguy56 Kohler Generators 1 09-30-2005 11:48 AM
Kohler Generator Randy Kohler Generators 0 01-14-2004 11:32 PM
Kohler generator Gary Springer Kohler Generators 1 03-06-2003 01:45 PM
kohler generator steve hawes Kohler Generators 0 04-05-2002 08:21 PM
