onan generator/welderI have an old onan generatorwelder, it ia an opposed two cylinder gas engine the only numbers i...this thread has 2 replies and has been viewed 1143 times
I have an old onan generatorwelder, it ia an opposed two cylinder gas engine the only numbers i could find are, 170-1542 on the manifold. i'm assuming thats a part number. on the cover under the starting instructions and spark plug gap specs it has the number 98A1372. Under the fine control adjustment for the welder it has 99C1122.It runs good produces power and welds ok i would like to know what kind of power output it has and what the rpm should be set at for 120 V power speed and for welding. any help would be greatly appreciated.
If you check some of the earlier onan post you will find a phone number for onan this is a good place to start. Are both the engine and the welder made by onan or just the engine only. I have a welder/gererator with an onan engine and a marquette welder the rpm for my unit is 3000 for welding and 1800 for AC power. It sounds to me from what info you posted that you have a cck series engine the different series were cck,ccka,cckb. If i am correct the only thing to change among these was the HP but dont take my word for it. I hope this helps you sometimes it can be hard to find info on onan products.
The 1800 RPM rating would seem to indicate a four pole alternator for 60 CPS. The other practical speed would be 3600 for a two pole alternator. A more elderly unit might even run at 1200 RPM, or even 900 RPM.
| Generator/welder | AJH | Welding Shop | 4 | 12-02-2007 07:32 PM |
| Need Help, Onan generator/welder | Warren Fehr | Onan Generators | 0 | 10-08-2007 08:23 PM |
| Need Help, Onan generator/welder | Warren Fehr | Onan Generators | 0 | 10-08-2007 08:16 PM |
| "The Bug" (Onan welder generator) | MUSCLE | Onan Generators | 3 | 03-06-2007 10:03 PM |
| onan welder/generator ck-s-259k | bmarsan | Antique Gas Engine Discussion | 0 | 03-26-2006 02:59 AM |
