Generators & Motors General Discussion Antique Generators, Light Plants and Old Electric Motors: Questions and answers about restoring and showing old power generation systems.
Delco Generator
I am beginning to look at a Delco I acquired about two years ago. The tag says Service number 4051,...
this thread has 2 replies and has been viewed 1193 times
Old 11-17-2001, 12:25 AM
Ken
Default Delco Generator
I am beginning to look at a Delco I acquired about two years ago. The tag says Service number 4051, Model 8XB3, 32V, 800 Watt, 25 AMP, 1750 RPM. It has a Zenith carb and is painted blue.
What age is it, what oil is used in engine, and what is correct spark plug?
Any and all help would be appreciated.
Old 11-18-2001, 02:01 PM
Don C. Wiley
Default Re: Delco Generator
Ken;
The information I have is as follows:
The bulletin I have is dated 3/27/36 and it shows the 8XB3 a "32 volt hand operated battery charging engine-generator."
Another bulletin dated 4/15/44 lists the 8XB3 with--carburetor-- speed control, Delco-Light battery--ignition, Delco-Light battery--output at generator, 21 amps @ 38 volts--AC spark plug #46--Jet size #17--Throat 17/32"--fuel capacity, 5 gallon--fuel consumption hours per gallon, 4 KWH--oil capacity, 4 pints--oil comsumption pints in 24 hours, .6--engine horse power, 1.3--bore 2-9/16"--storke 2-9/16"--piston clearance,.0025--valve adjustment,.010--speed in RPM 1650 to 1800.
If you need any more information let me know.
"DELCO DON"
Old 11-18-2001, 06:31 PM
Gus Simms
Alright Don, how'd you get the animated smilies?
Delco generator Eric S. Generators & Motors General Discussion 2 02-19-2006 11:39 PM
delco generator FredK1037 Antique Engine Photos 0 07-15-2005 09:29 PM
AC Delco generator Bud Smith Generators & Motors General Discussion 0 07-09-2004 07:19 PM
Delco B-6 generator Kelly Reynolds Generators & Motors General Discussion 7 02-09-2001 06:27 PM
b-6 delco generator 6v Bill Pitts Generators & Motors General Discussion 1 01-09-2001 03:07 PM
