Kohler Generators
WANTED KOHLER PART
Looking for a source for a water pump for the engine on a 1951 Kohler light plant or parts to...
this thread has 3 replies and has been viewed 976 times
Old 12-27-2001, 11:10 PM
WILL
Default WANTED KOHLER PART
Looking for a source for a water pump for the engine on a 1951 Kohler light plant or parts to rebuilt it. Kohler says parts are no longer available. This is for the little 4 cylinder engine with 2" bore. Thanks in advance!
Old 12-31-2001, 07:33 AM
Gus Simms
Default Re: WANTED KOHLER PART
If yours is the OHV engine, it will be the first I've ever heard of with a water pump. All the ones I've had and have seen were thermo-siphon. The larger flat head engines have water pumps, the smallest of which I can find lists a 2 3/8" bore. Where does the pump drive from?
Old 07-09-2006, 11:11 AM
Brett B. Brett B. is offline
Hi will, just going over some old web listings and came accross you question. I have the same problem and wonder if you got yours rebuilt and who did it!!!
Old 07-21-2006, 04:45 PM
abluechev81 abluechev81 is offline
Talking Re: WANTED KOHLER PART
if you have a l600 engine like my 2e22 kohler gen parts are available just 1 problem the org book numbers where changed in 1974 so lotts of the parts are available if you have the right number try part 240648 this is a repair kit cost is $62 i bought it last year. there is also another one in the book my book covers spec#0- 50
Oil City Halfbreed part wanted machinels Oil Field Engines 1 04-17-2007 01:24 AM
Kohler generator....Need Part Tolly Kohler Generators 1 10-12-2006 01:06 PM
Older Kohler Help Wanted Steve A Kohler Generators 0 06-12-2005 09:32 PM
Generator part wanted! Tom Schaech Generators & Motors General Discussion 0 12-08-2004 07:28 PM
part wtd.kohler light plant fred kengeter Kohler Generators 0 07-31-2002 11:57 AM
