Kohler Generators
kohler AC or DC?
Hi: This kohler 4 cyl. water cooled power plant was listed here a while ago as 115 volts. from...
this thread has 7 replies and has been viewed 522 times
Closed Thread
Old 01-12-2002, 11:34 PM
Tom Marshall Jr.
Default kohler AC or DC?
Hi: This kohler 4 cyl. water cooled power plant was listed here a while ago as 115 volts. from these numbers can anyone tell if it is AC or DC?. Model No. 1M21-U No. 101117 If anyone needs to look at it, if you e mail me i can give you the number on e bay. I'm unsure what i can post here. Thanks for any help, Thanks to Harry for the place to look. Tom
Old 06-08-2003, 01:57 PM
Mike Shearer
Default Re: kohler AC or DC?
Hello Tom
I have an Explanation for the 1m21 model code if this helps.
"In models below 1000 watts first numerals indicate capacity in KW. (1= 1KW)
The first letter following the numeral indicates methode of starting. (M= manual)
The second, third and fourth letters indicate special modifications. (2 in 21= 120 volts AC! and the 1 in 21 indicates 1 phase with 2 wires)
No other information on the "U" part in the model number.
Hope this helps.
Sorry if this answer took so long but I only found this site yesterday.
--mike--
Old 06-08-2003, 08:30 PM
Howard Yoshida
Aloha, the way I determine if it is ac or dc is by using an analog vom meter. Put your probes across the output and set your meter to the highest scale if voltage is unknown and select ac on your meter. If it is ac there will be a reading and if you select dc there will be no reading.If it is dc, there will be a reading if the meter is set to dc and also there will be a reading if set to ac (usually a little higher than dc). I use a Simpson 260 vom and it works for me but I would assume different brands analog,or digital will work the same and if it doesn't, I would like to hear about it.
Mahalo, Howard
Old 06-09-2003, 01:33 AM
Franz
Probably the single source of Kohler information is Frank DeWitt's page. http://www.home.eznet.net/~fdew/kohler1.htm
Frank's Kohler Page
Old 06-13-2003, 03:38 PM
Russ Hughes
Are you sure about that first setting? If an analog meter is set for AC, it will also read DC, but not accurately. if you set the meter to DC, it will read DC, but not AC.
The meter movement itself is a DC movement and the meter assembly will have a small rectifier to change the AC to DC so the DC meter movement will read AC. When yo switch the meter to DC, the rectifier is not in the circuit anymore.
In summary, a DC meter wont read AC. An AC meter will read AC and also DC, but not DC accurately
Old 06-13-2003, 08:43 PM
Howard Yoshida
Aloha, yes you are correct. Somehow I made a boo-boo. Sorry about that, sometimes I do things without thinking.
Mahalo, Howard
Old 06-16-2003, 04:00 PM
Russ Hughes
Howard, you must be a member of the same club I belong to. We have a lot of company. Been there, done that many times
Old 06-16-2003, 10:23 PM
Howard Yoshida
Aloha Russ, yeah and guess what I got for father's day? My daughter gave me a Sony Handycam and the instruction book is about 1/2" thick with zillions of instructions so now I am in trouble.
Mahalo, Howard
Closed Thread
KOHLER of KOHLER Electric Plant rvaccaro2 Kohler Generators 0 09-02-2007 07:11 PM
Kohler 7.5 RMK - Help! Mark Briggs Kohler Generators 3 12-22-2006 02:28 AM
old old kohler vanwest Kohler Generators 1 08-09-2006 11:01 AM
Kohler value? Dewey Kohler Generators 31 08-17-2005 12:57 PM
Kohler 2 cyl.gen,set. Arthur Kohler Generators 1 07-21-2005 11:27 PM
