kolher 2 cyl?i just recently was given a 2-cly generator it has kolher engraved in to the casting of the block...this thread has 1 replies and has been viewed 587 times
i just recently was given a 2-cly generator it has kolher engraved in to the casting of the block along with 800 watts...its a manuel start and has no valve cover... if anyone out there knows what i have and/or how much its worth i'll greatly appreciate it......thanks alot...mike
Assuming that your Kohler is air-cooled, it would be 110 volt D.C. The manual start version was designated as a Model "T" made from 1924 to 1942. The automatis start version was designated as Model "S", and if the unit had a vapor gas carb, it would be designated as a Model "TA" or "SA" ("A" represented artifical gas). Don't bother looking for a valve cover, they never had one. The units made from 1924 to around 1930 had a Stewart Warner vacume can style fuel pump, after around 1930 they had a mechanical fuel pump, driven from an excentric on the oil slinger gear. Some of the Kohler 800 watt units had an automotive style ignition coil, but I think that most of them had a magneto inside of the flywheel. The points, condencer, rotor, distributer cap, can be bought at any local auto part store, they are the same as the Wisconsin Model "TH" or "THD". Some of the later units had a casting date scratched in the sand when poured, it would be clearly visible on the bottom of the engines base.
I have two running generators of this style, made from the best of four, so I have many extra parts if needed. Feel free to contact me if I can be of more help. |
| Kolher Genset Rebuild...wow, what a job.... | ReadyKW | Kohler Generators | 12 | 10-01-2006 09:51 AM |
| kolher i think | Dick-CT | Kohler Generators | 17 | 07-19-2006 04:05 PM |
| Kolher/Wauesha Help | loucavaliere | Kohler Generators | 1 | 01-21-2006 09:50 PM |
| Kolher 4A27 4 cyl 4kw help | Brian Carrick | Kohler Generators | 5 | 02-16-2005 10:27 PM |
| kolher | mike ranieir | Kohler Generators | 2 | 03-23-2002 01:01 AM |
