Kohler Generators
kolher
does anyone know where i can get timing specs ...or a parts listing??
this thread has 2 replies and has been viewed 511 times
Closed Thread
Old 03-22-2002, 06:20 PM
mike ranieir
Default kolher
Old 03-22-2002, 07:47 PM
Gus Simms
Default Re: kolher
Can probably help, but need more info. A model number or description?
Old 03-23-2002, 01:01 AM
Bill Garman
Default Re: kolher
Timeing on Kohler 800 Watt D.C. There are two marks on the flywheel; one marked "DC" (top dead center), and one marked "SPK". With points set at .012 to .015, Using a timing light, set distributer to where the "SPK" line flashes on top of the flywheel in line with cylinders. The engine fires at 180 degrees, so either plug wire, or distributer center wire will give the same result. Without timing light, set distributer to where points just start to open as the SPK mark comes up to the top center.
Closed Thread
Kolher Genset Rebuild...wow, what a job.... ReadyKW Kohler Generators 12 10-01-2006 09:51 AM
kolher i think Dick-CT Kohler Generators 17 07-19-2006 04:05 PM
Kolher/Wauesha Help loucavaliere Kohler Generators 1 01-21-2006 09:50 PM
Kolher 4A27 4 cyl 4kw help Brian Carrick Kohler Generators 5 02-16-2005 10:27 PM
kolher 2 cyl? mike ranieir Kohler Generators 1 03-22-2002 01:41 AM
