Regulator for Onan brush type gen set 25KWI have an old Onan 25KW generator powered by a Ford 6 cyl gasoline industrial engine. The unit runs...this thread has 3 replies and has been viewed 703 times
I have an old Onan 25KW generator powered by a Ford 6 cyl gasoline industrial engine. The unit runs well, but the voltage regulation circuitry is troublesome (old relays that stick, etc) My question- is there a modern replacement voltage regulator I can retrofit to this unit? It is a brush type, most regulators I have seen are for brushless units.
While searching, found this older thread that applies to my question. Attached is nameplate (provided by current owner so I can not get a better one yet). Genset has electro-mechanical voltage regulator that does not work steadily. Can these be repaired or replaced with something better? Thanks
Check out a company called power-tronics they have what you need.I have used them for years,good products and great help from the tech department.
| Onan 7.5JB regulator | JBittnerSr | Onan Generators | 15 | 10-29-2008 05:10 PM |
| Onan 5 CCK-3 Brush arcing | Tom Bethel | Onan Generators | 9 | 10-13-2007 09:27 AM |
| Onan 300-1404 regulator | Perplexed | Onan Generators | 9 | 05-31-2007 04:10 PM |
| Please help: Old Winpower brush-type generator/starter wiring | norcalpablo | Generators & Motors General Discussion | 1 | 05-30-2007 11:52 PM |
| onan 25kw ? | Michael D | Onan Generators | 5 | 01-11-2006 01:41 PM |
