Hobart welder-generatorI have a Hobart Model G213, 200 amp welder with a 3kw generator powered by a 2 cylinder Wisconsin...this thread has 3 replies and has been viewed 2422 times
I have a Hobart Model G213, 200 amp welder with a 3kw generator powered by a 2 cylinder Wisconsin engine. The engine runs good but I have no power output--NONE. I've been told something about flashing the generator to restore the magnetic field, but have no idea how to go about it. The unit appears to be in nice shape, the brushes are all free and the armature they ride on is clean. Your thoughts, Please. Al
I'm not sure if this will work on a Hobart, but it does on Lincolns. Remove the exciter cover and while the machine is running, pull one of the exciter brushes back a few thousanths till it is arcing to the commutator. Hold it there for a few seconds. This should get the machine working.
I ALSO HAVE A HOBART 200 AMP MODEL G-213. THERE IS A COIL THAT LOOKS LIKE IT IT IS BRASS WITH FIVE WIRES RUNNING TO IT. IT HAS CERAMIC SPACERS IN BETWEEN THE COILS. I THINK THAT IT CONTROLS THE HEAT RANGE BUT I AM NOT SURE. WHAT IS THIS PART CALLED? AND CAN I GET A REPLACEMENT FOR IT? MINE BROKE AND I FIXED IT,BUT I AM NOT SURE HOW LONG IT WILL LAST.
We tried to purchase the ceramiic spacers for the same welder 2 0r 3 years ago aand they were no longer available. Miller purchased the hobart welding line and basically puts the hobart name on miller products Their website is millerwelds.com you can try and see if the coil is available.
| Hobart Bros Simplified Arc Welder/Generator | Curtis Montgomery | Welding Shop | 4 | 05-16-2008 09:14 PM |
| 1920's Hobart Bros Welder/Generator | mnfarmgirl | Welding Shop | 4 | 12-09-2007 12:08 PM |
| hobart welder conversion to generator | robbieo11 | Generators & Motors General Discussion | 4 | 01-06-2007 10:30 PM |
| Hobart Welder/Generator | Martin Dollar | Welding Shop | 2 | 12-23-2006 02:47 PM |
| Hobart welder - generator lead insulation | steve mn | Welding Shop | 4 | 07-20-2004 03:13 PM |
