Kohler Generators
volts regulator
Is there anyway to run a kohler generator with out a voltage regulator part # 233833 ?
this thread has 2 replies and has been viewed 1244 times
Old 12-23-2002, 04:06 PM
Gerry
Default volts regulator
Old 11-22-2004, 12:21 AM
straubpower straubpower is offline
Default Re: volts regulator
No you will need an avr unless you stand by the set and regulate it by hand. But generally you do not need to replace the AVR with original equipment brand. We replace most OEM AVR with after market unit just because of OEM pricing.
But most sets will accept any brand name regulator. We have some very inexpensive units which will power most sets.
Old 05-30-2006, 12:58 PM
Wayne Johnson Wayne Johnson is offline
Hi,
I have a Kohler 7.5R generator in need of a voltage regulator, part # 233833.
Could you suggest a place to order this regulator or a replacement?
Thanks,
Wayne
118 Volts OK? Luker Onan Generators 5 12-03-2006 11:18 PM
12 volts to 6 volts Alan R Magnetos, Ignition Coils and Spark Plugs 13 09-28-2005 03:42 PM
Too Many Volts desighitter Onan Generators 9 03-05-2005 01:19 AM
mep 016 169 volts instead of 120? Lee Alessi Generators & Motors General Discussion 5 09-04-2004 01:54 PM
Why 32 volts Tom Jamboretz Generators & Motors General Discussion 17 02-01-2002 04:55 AM
