Kohler Generators
Kohler Power Plant - Parts Help?
Buying a Kohler model #6.5C67 Serial #290558. Also has a number below the model number of 5080A8/4....
this thread has 3 replies and has been viewed 949 times
Closed Thread
Old 06-13-2003, 01:03 AM
Brian Foster
Default Kohler Power Plant - Parts Help?
Buying a Kohler model #6.5C67 Serial #290558. Also has a number below the model number of 5080A8/4. The unit is 120/240, liquid cooled, 1800rpm. I'm looking for parts availability / engine rebuild kit info, etc. Seems it has a Continental engine. Any info is greatly appreciated. Any toughts how old?
Old 06-13-2003, 12:58 PM
Mike Shearer
Default Re: Kohler Power Plant - Parts Help?
Your Ser. number Date code range for Kolher is ser#285103 = 1966 ser#295500 = 1967
Old 06-13-2003, 08:52 PM
Harold Hunt
Have you made a positive ID that it is a Continental? Do you have any pictures?
I have a Onan with a N56 Continental and a forklift with a F163. I am semi familiar with the other Continental engines as well.
Engine parts are still availible at industrial strength auto parts, the chain stores probably don't have a clue.
Harold
Old 06-13-2003, 10:35 PM
Harvey Teal
Teledyne Continental will give you more help with engine manuals and parts than you can imagine. Also many older independent auto & ag parts stores, forklift dealers, and welding supply companies will have parts for your Continental. I have an Onan genset with F163 engine, had to deal separately with Teledyne & Onan but was very successful. Your challenge will be to find manuals & parts for your generator head. Again, talk to older welding supply houses if you don't have luck with Kohler.
Closed Thread
Power plant identification and parts dfb Kohler Generators 6 11-19-2007 11:45 AM
4cm21 Kohler Power Plant Jeff Woollett Kohler Generators 5 11-02-2003 09:09 PM
Kohler power plant larry rusch Kohler Generators 5 10-14-2003 02:15 AM
Antique Kohler 5R21 Power Plant Mike Shearer Kohler Generators 2 06-10-2003 01:15 AM
kohler 4 cyl power plant Dennis Terry Kohler Generators 0 03-25-2001 07:51 PM
