Kohler Generators
Kohler L654/7.5062 genset
I have a Kohler l654/7.5062 genset, Gen model# 7.5062 sn= 242459 spec# 106297-A 7kw 7kva phase-1...
this thread has 3 replies and has been viewed 2792 times
Closed Thread
Old 06-22-2003, 10:45 AM
Merlin Tice
Default Kohler L654/7.5062 genset
I have a Kohler l654/7.5062 genset, Gen model# 7.5062 sn= 242459 spec# 106297-A 7kw 7kva phase-1 hz60 120-240v 29.2amp 12v 1800rpm. I am looking for a wiring diagram or manual for this. The problem I have is that someone disconnected wires # 1,2,3,4 from the L1,L2,Low, and ground. I need to know which wire goes where to get my power output. Any help very welcome.
Old 08-06-2005, 02:36 PM
Dtarsi Dtarsi is offline
Default Re: Kohler L654/7.5062 genset
Merlin,
I have the about the same problem with my 7.5C62 spec 106281-A S/N 261004 unit. Cannot locate a users manual with engine and alternator schematics. When I get into the actual wiring I'll let you know were those connections go. Also, if you contact a Kohler parts area they may be able to supply the wiring schematic. If I find one I will send it.
Dtarsi
Old 08-06-2005, 06:12 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Usually if you have a 4 wire 120/240, you have two seperate 120Vac windings. For 120Vac only connect the two in parallel. 1-3 2-4 Power from
1/3 and 2/4= 120Vac...For 240Vac connect in series. 2-3, Power from 1 and 4 = 240Vac...For 120/240Vac 2-3= Neutral, 1=L1 4=L2, and 240Vac= L1 and L2 120Vac L1 to Neutral, and L2 to Neutral..... Hope that helps.
Bruce in alaska
Old 09-01-2005, 11:16 AM
springsman
Thumbs up Re: Kohler L654/7.5062 genset
I have a manual. Send me an email if you still want it.
Closed Thread
Difference between Kohler L600 / L654 ? Arthur Kohler Generators 4 12-31-2008 09:11 PM
Kohler 7.5062 HELP jchvy1 Kohler Generators 18 10-06-2008 12:29 PM
1985 Kohler L654 4cyl flathead surges dkeeney Kohler Generators 5 10-08-2007 01:25 AM
KOHLER 7.5062 VINCE Kohler Generators 0 08-26-2004 01:09 PM
