Welding Shop
hobart Welder question
I have A hobart G300 welder poweed by a 6 cylinder chrysler. It sat in the barn and rats ate the...
this thread has 2 replies and has been viewed 3311 times
Old 02-29-2004, 09:36 PM
flskip
Default hobart Welder question
I have A hobart G300 welder poweed by a 6 cylinder chrysler. It sat in the barn and rats ate the wires off the exciter coils. I replaced the coils with working coils of the same number from a G261 (jeep powered welder) When Installed the coils in the G300 the unit would not excite. The 4 brushes are free and im only getting 1.1 to 2.4 vdc to the receptical on the control panel. The voltage is the same if i unhook the coils also. Would the coils need to be polarized even if they came from a working welder that had been run a few days prior? I have heard that they could of lost there residual magnitizism. I assume polarizing them would solve this. Any help with should I or do I need to polarize them? Also am open to any suggestions of how to polarize exciter coils.
Old 03-01-2004, 09:33 PM
Harold Hunt
Default Re: hobart Welder question
Taking the coils off would disrupt the residual magnetic field.
Does this gen use the generatot to start the engine, a regular starter motor or Both? If it has the gen as a starter using that should recharge the coils.
Re flashing the field takes a small power source ( some use a couple of d batteries or a 9V battery ) This trick is to know what polarity the exciter wires are then apply power to the field then run the engine untill it produces power.
Harold
Old 10-08-2007, 06:11 PM
elnav elnav is offline
Does anyone have a wiring diagram for a Hobart G-213 welder/genset? Pdf format would work fine.
Thanks in advance
Help! I need info on this Hobart welder Super-Rides Welding Shop 18 08-15-2008 05:07 PM
Vintage Hobart Welder question. JBailey Welding Shop 3 08-17-2007 03:57 PM
old hobart welder Dan Potter Welding Shop 1 06-16-2007 02:54 PM
Old Hobart Welder DaveHath Welding Shop 7 01-10-2006 09:17 AM
DCC-353-P Hobart Welder Rob-n-LA Welding Shop 2 07-17-2004 04:55 PM
