Need Info on 10kw Kurz & Root Generator
Greetings, I have just acquired a Military surplus Kurz&Root (Appleton WI) generator. Here is the...
this thread has 5 replies and has been viewed 1118 times
Old 04-26-2004, 04:40 PM
k4bg
Default Need Info on 10kw Kurz & Root Generator
Greetings, I have just acquired a Military surplus Kurz&Root (Appleton WI) generator. Here is the data: USA-A Stk#6115-863-1498. S/N 560-1547, Model FERO-1 Mfg - 3/64, Ratings 1 & 3 ph 240/208vac, 10KW , 12.5kva. Under USA-C it lists model # 1700M1088, S/N 60-1547N619. D.C.Exciter 600w @17vdc @35A. PF 8 . The engine mfg is Hercules by Hupp Corp of Canton OH. spec:IBERX11, S/N 3667695, mfg 9/25/63, 4 cyl flathead gas Bhp 29.3. Mil Spec E 11275B. Requires 24vdc battery power. The unit is complete excepting tool kit and manual. It includes the lubricant heater assy. All attached schematic diagrams are readable. The unit has not been run in several years. The oil in crankcase looks clean. The exhaust is rotten. I plan to go through the fuel, ignition mag , and cooling systems, cleaning, lube ,etc. If anyone is familiar with this fine machine I would greatly appreciate hearing from you and learning from any advice you may care to offer. Parts sources, etc. would be appreciated. I do not want to tare into something I might regret. I am new to the site. Thanks for the posting. Regards, Bob
Old 04-30-2004, 07:30 AM
mike grant
Default Re: Need Info on 10kw Kurz & Root Generator
I have a kurtz & root mode lkr-10 ms generator unit minus the engine i'm trying to figure out how to get field excited to make it work i'm adapting a 58 h.p. diesel engine to it the unit rated to 3600 rpm any info would be much appreciated
Old 08-05-2004, 01:18 PM
d.moffitt
Default need infi on 40kw kruz&root gen
i also just bought a kruz gen. a 1986 modle # mepoo6a powered by a allis chalmers 3500-a diesel. need to find opperators manual for the generator end. this is a militery unit # nsn 6115-00-118-1243.
Old 02-06-2005, 01:33 PM
AnOldMan AnOldMan is offline
I have information on the unit d.moffitt is describing. It is a 60kw unit and can be re-wired for single phase operation. The article I posted about it is here: http://www.anoldman.com/modules.php?name=News&file=article&sid=21
I also have the complete manuals in pdf format.
TM-5-6115-545-12.pdf Operation
TM-5-6115-545-34.pdf Maintanance
TM-9-6115-545-24P.pdf Parts
I have a paper manual TM5-6115-464-12 for similar units MEP-004A MEP-103A and MEP-113A if anyone is looking for this information.
Old 02-06-2005, 02:23 PM
wwIItrucks wwIItrucks is offline
Bob,
I have the same gen set. Mine is a FSN # 6115-833-1498. Mine was built in March 1966. Good luck trying to find manuals . I have looked for many years without luck. The best bet would be if your data plates with the wiring schematics is still there. Try Afcon Products (they are the new owners of Kurz Root) for more info. 1-800-958-9920.
The hercules engine is easy to work on and parts are easy to find for the IXB series engines.
If you want more info, let me know.
Jeff Jensen
wwiitrucks@aol.com
Old 10-13-2009, 02:49 AM
Joski Joski is offline
Hi, I just purchase the same generator 1965 manufactor date. Did you have any luck finding manuals? I do have all the wireing diagrams from the covers of the unit. Thanks, joe
Kurz & Root Generator Scott P Generators & Motors General Discussion 7 10-18-2004 05:09 AM
Kurz & Root Generator Jim Bosse Generators & Motors General Discussion 0 04-04-2004 12:52 PM
Kurz and Root generator Jeff Dyrud Generators & Motors General Discussion 1 02-05-2004 11:02 PM
KURZ AND ROOT GENERATOR JERRY REVELL Generators & Motors General Discussion 0 04-01-2003 12:25 PM
KURZ & ROOT GENERATOR mo Generators & Motors General Discussion 7 01-21-2001 03:54 PM
