sears 1100 watt wont generate
this thread has 3 replies and has been viewed 1949 times
Old 08-08-2004, 04:16:45 PM
Paul J. Morrison
Default sears 1100 watt wont generate
Im working on a sears & robuck 1100 watt gen set. Motor runs good and unit was generating as recent as 6 months ago. Inside is clean and not coroded. brushes and comutator appear in good condition. Could this unit have lose its residule magnetism in this short period?, or should I be looking for another problem? model # 580.5356-1 serial # 0179237
Old 08-08-2004, 05:02:49 PM
roy
Default Re: sears 1100 watt wont generate
remove the end cover and locate the brush leads. Should be marked + and -. Disconnect the leads and hook a jumper lead to each brush Start the engine and touch the jumpers to a 9VDC battery, assuring correct polarity. The motor RPM should drop. Reconnect the brush leads with the engine off. If you have to do this each time, the rotor is pooched. The residual magnetism should hold.
Old 08-09-2004, 04:21:03 PM
Paul J. Morrison
Thanks for the fast reply. 9V. battery,like a run down 12v car battery ?, or 6v tractor battery?
Old 08-19-2004, 10:45:53 PM
John McPherson
No, too awkward, but they could be used for a momentary charge.
A 9 volt transistor battery ought to be adequate if it is reasonably charged.
Clinton 1100 series question James Wallace Small Air Cooled Gasoline Engines 4 12-03-2007 07:48:17 PM
Clinton D-1100...no head gasket ryan68bug Small Air Cooled Gasoline Engines 2 07-06-2006 02:27:36 AM
Clinton D-1100 spark plug wire lead or connector tip needed ryan68bug Small Air Cooled Gasoline Engines 1 06-29-2006 06:30:58 PM
Proper color for mid '50s Clinton D-1100 engine? ryan68bug Small Air Cooled Gasoline Engines 1 04-20-2006 12:28:23 AM
!A21U 1.5kv won't generate Steve Boller Kohler Generators 1 06-13-2005 07:56:55 PM
