mep701a
i won this over at gov liquidation. anyone have a manual on pdf?? is it possible to convert it...
this thread has 6 replies and has been viewed 1103 times
Closed Thread
Old 08-15-2004, 09:16 AM
Lee Alessi
Default mep701a
is it possible to convert it to 12 volt starting? can i just change the starter? or do i have to change the guages too? what else?
also does it use jumper cables, or can i put 2 12volt batteries in it???
Old 08-22-2004, 11:39 PM
Lee Alessi
Default mep701a,again, seriously...help
i picked it up, it runs. apparently it was mounted to a trailer (its not anymore) i see inside the cover that there are lugs, that are apparently to wore up 220....?? i see cable brackets and then down my the exhaust port there is another rubber grommet. i assume this was the output the army used on the trailer.
it has no output at the 110v civilian outlet. i can get it to 60hz by varying the throttle, and it looks like 150volts on the guage.
i dont mind working on it, as i drive a m715 usmc truck as a daily driver, and built it myself. i just have NO generator experiance
Old 08-24-2004, 09:39 AM
Lee Alessi
Default Re: mep701a,thanks for the help...
wow, thanks for all the emails. i checked output at l0, l1,l2,l3 and get nothing. yes the breaker is on. also it still says 60hz, 150volts and the voltage increae/decrease knob has NO effect
Old 08-24-2004, 12:33 PM
Lee Alessi
Default how to checck a voltage reg??
how do i check and see if thats the problem??
Old 08-24-2004, 05:42 PM
Lee Alessi
Default Re: how to checck a voltage reg??
no power at the braker, or lugs.
if i connect a multimeter to the back of the volt guage, should it say what the front says?
Old 08-25-2004, 04:12 AM
lee alessi
Default it works!!!!!!!!!!!!
ok, the fuse holder was bad on the front panel, the 120volt home socket now works. ok. in single phase 120 i get 120 at the socket, correct?
L0 is ? L1 is ? L2 is ? L3 is ?
what L terminals do i use for additional 120 output? do i use 1,2 or can i use 1 AND 2?
in 220 single phase, does the socket remain 120? or does it go to 220??
say i want to power lots of stuff in 220 (the switch allows 120, or 220, not both) as well as three phase..... what l terminals do i use?
my multimeter seems to be acting up, but i dont want to fry the genset..
Old 12-10-2008, 05:47 AM
gotco gotco is offline
Default
there should be a legend calling out the connections if not set the switch and use a known good meter. the question of 120/240 single phase has been seen before to my knowledge these do not put out split or byphase voltage. the simple solution is an isolation transformer 220 in 120/240 out problem solved.
yes if you wish to do a redesign simple solution 24 battery or 2 12 volt in series both will work depends on unit setup and space available.
Do you know the noise level or the engine manufacter or engine speed?
(Edit: The original post activity was dated 2004.)
Closed Thread
