Onan 12.0 MDJC Genset
Hi Folks, I have an Onan 12.0 MDJC Genset that is only putting out 60 volts. It runs fine and...
this thread has 4 replies and has been viewed 1950 times
Closed Thread
Old 08-24-2004, 11:32 PM
Mike_novick
Default Onan 12.0 MDJC Genset
Hi Folks,
I have an Onan 12.0 MDJC Genset that is only putting out 60 volts. It runs fine and doesn't bog down under load (although at 60 volts the lights are pretty dim!). Reving it up doesn't help either. I took it apart as far as I could but I haven't a clue what to check. Might anyone have any suggestions on narrowing down the problem.
Thanks! -Mike Novick (mike_novick@yahoo.com)
Old 08-25-2004, 12:11 AM
Jim McIntyre
Default Re: Onan 12.0 MDJC Genset
The voltage regulator is the most likely culprit. If you're lucky, the adjustment trimmers on it have gone intermittent. Carefully turn them a bit, making sure to set them back where they were. If you're not so lucky, the V/R may need to be replaced. Check here for a non-OEM cheaper alternative:
http://www.partsfortechs.com/voltregulators.htm
Old 08-25-2004, 05:27 PM
Billy J Shafer
Need to know the model and serial number of your unit.Is it a magnaciter unit.
Old 08-25-2004, 10:32 PM
Mike_novick
Buy Jim a beer! That was just the direction I needed. I had to knock the coarse adjustment around a bit to get is somewhere between 60 and off-the-scale. But then the fine trim brought it into a steady 110V. Many, many thanks... -Mike
Old 08-25-2004, 10:38 PM
Mike_novick
Hi Billy,
Thanks for your input. Luckily it turned out to be a finniky voltage regultor.
Cheers,
-Mike
Closed Thread
Onan 12.0 MDJC Doug101 Onan Generators 2 03-26-2008 06:25 PM
Onan Gas Genset - Need Help with ID mhinkle Onan Generators 1 08-12-2006 01:09 PM
Used Onan JC GenSet John C Onan Generators 5 11-05-2005 11:45 PM
Onan Genset Bill Sherlock Onan Generators 3 02-05-2004 01:10 PM
Onan genset Greg Downard Onan Generators 1 04-10-2003 10:07 PM
