Generac by sears
I have a 3750 watt generator that will not put out proper voltage. I have done some tests and think...
this thread has 4 replies and has been viewed 791 times
Old 09-25-2004, 02:56 PM
looney-bin
Default Generac by sears
I have a 3750 watt generator that will not put out proper voltage. I have done some tests and think that the problem is in the regulator. The excitor is outputing 25 volts but the rotor leads only register 3 volts DC. If I apply 12 volts to the stator the generator will output close to the proper voltage. So if I am on the right track, where can I get a replacement regulator at a reasonable price? Or info on repairing this one? Thanks.
Old 09-26-2004, 01:25 AM
roy
Default Re: Generac by sears
The Generac generator and pressure washer divisions are now owned by Briggs and Stratton. Sears has a nasty habit of making changes on their products so the owner has to go to them for parts and service. If the part was made exclusively for Sears and they no longer stock it you could have a problem.
Old 09-27-2004, 12:35 AM
looney-bin
Thanks for the tip. Did some looking and found that the XL or PRO series of the B&R use a regulator and has the same wiring. Am planning to order one and try it. When you compare $55 for the B&R to $271 for the sears unit, I think it's worth a try. Any input would be welcome as my thinking has been known to be dangerous at times.
Old 09-28-2004, 10:41 AM
John McPherson
It should work. You did the background that the "average homeowner" would not know how to do (which Sears banks on), so it ought to work. The only differences might come in wire color coding (small chance).
Old 09-28-2004, 05:35 PM
looney-bin
Thanks,
I was hoping that would be the case. I was not quite sure how picky the system would be and if it could handle any differences in the windings. Since this unit covers several sizes of generators I figured it would. I just needed that warm fuzzy to go ahead with it. And your right, I am not your "average homeowner" but this is the first time I have dug this deep into a generator.
Thanks again.
Old RV Generac Arthur Generac Generators (SEARS, etc.) 9 09-11-2009 09:37 PM
Have patience (Generac) realkeifer Generac Generators (SEARS, etc.) 10 04-30-2008 12:45 PM
Generac ChrisMar Generac Generators (SEARS, etc.) 1 02-10-2008 05:49 PM
Generac engine,what is it? Arthur Generac Generators (SEARS, etc.) 18 01-27-2005 11:52 AM
generac pwest Generac Generators (SEARS, etc.) 1 09-14-2004 11:51 AM
