Craftsman Generator PartsHelp... I have an old Sears 7kw generator, Model 580.321460, and I am in need of replacing the plug...this thread has 6 replies and has been viewed 6943 times
Help... I have an old Sears 7kw generator, Model 580.321460, and I am in need of replacing the plug in rectifer bridge that has fried. The maching is too old for Sears to cover and hate to have to buy a new generator just because of one cheap part.
Larey
You have a Generac generator (580.0000) made for Sears. Contact the Generac people. http://www.generac.com/ Jim |
And if Generac is unable to help, one can assemble one if needed, or depending upon physical size, a discrete replacement might be an off the shelf item at low cost from a supplier like Mouser. I have been doing that route for years with many varied pieces of equipment.
Thanks for the great information, I am checking with Generac to see what they can do, if not, it looks like I might need to find a subsitute.
Below is the new # for the rectifier for a 4kw Sears, probably the same, available through Briggs, which owns Generac Portable Power. The link is for generac / Briggs dealers..
Mike You can purchase a new rectifier, part #79569GS (NEW number!), through a local service dealer or through Sears Parts (800-366-7278). The dealers nearest to you can be located at this link: http://www.generac-portables.com/ser...tor/index.cfm/ |
If it is the square type bridge rectifier with four terminals you can buy them at Radio Shack. I have also salvaged them from some junk video cassette recorder that use them.
Kent |
First post, and I thought I would resurrect this old thread
. I ran across the same problem with a bad rectrifier in my 580.32402 1200 watt Sears generator. After many fruitless parts inquirys with Briggs and Stratton as well as Generac, I found two places that do carry this plug in rectifier. parts@cliffordpower.com admin@aidistributors.com This part fits many, many of the older Sears/Generac generators, from 900 watt to 4000 watt, near as I can tell. It is (was) sold under Generac part no. 79569. Other part nos. are 00728293, 28293, 28293GS, 79569G--for the same part. "GS" is a Briggs and Stratton suffix used when they acquired the Generac portable gensets division. Hope this helps someone! Chet |
| Craftsman 143.556072 generator | ncflatfender | Generators & Motors General Discussion | 2 | 10-22-2007 09:36 AM |
| Flywheel Sears Craftsman 3600 generator | ron_a | Generac Generators (SEARS, etc.) | 2 | 04-08-2007 01:19 PM |
| Rectifier board for Craftsman generator | Joe Stewart | Generac Generators (SEARS, etc.) | 22 | 10-12-2006 02:14 AM |
| Old Craftsman saw | MarkG | Chain Saw Collectors | 3 | 06-20-2005 01:21 AM |
| Craftsman Lathe - Need Help | Paul Maples | Antique Engine Archives | 12 | 09-15-2002 11:12 PM |
