Where have you run into any left hand threads?O.K. Stackers, On our old iron, specificly, where have you ran into any left hand threads?this thread has 43 replies and has been viewed 1942 times
My only offer is from my heavy duty '47 Ford truck. The left side lug nuts are all left handed threads, and the right side has right handed threads.
Like the trivia threads! Keep them coming.... Travis |
On my Sandwich saw rig the arbor nut for the blade is 1-3/8 x 6 L.H.
I used one today. How about the grease cap on the end of my IHC 1-1/2 M crankshaft.
I had a dishpan Fairbanks engine once that had a left hand thread on the pin for the cam roller, I think. I can't remember exactly.
Mike |
Thats a simple one!! The governor spindle and gear on Hercules and many other ones, has left handed threads!
No one has mentioned any small engines, yet. Hint hint
Flywheel nuts on small engines??
Mike |
ON A UPRIGHT NUWAY
Factory made engine trucks and horse drawn wagons.
The govoner nut on a John Deere E
Pulley on the flywheel side of a Briggs "Y". Lugs on my old 1970 Ford F-350. Flywheel nuts on the Briggs engines also.
Lawn mower blade bolt is backwards
I think Mac Leod |
Most Early Briggs Engine Flywheel nuts have left handed treads ~ Jonathan
Mouldboard plow bolts often have backwards threads.
The John Deere "E" engines like Doug said, have a left handed threaded shaft on the governor gear. Easy to break . Don't even ask how I know . Paul
The brake adjustment on my Minneapolis Moline tractor.
Most Ford trucks and vans over here had left handed wheel nuts and studs on the left hand side up untill the mid to late eighties.
Simon, on a wet and windy morning ready for the off, taking a two ton Dorman diesel to a show. |
I worked with a fellow named Red. He was a left handed nut. Tony
Flywheel, Cushman Cub Bean Special. David.
| Briggs FI crank threads...left or right? | Bruce A | Small Air Cooled Gasoline Engines | 2 | 03-13-2008 11:51 AM |
| 12HP Left Hand Reid | stfarms | Oil Field Engines | 2 | 12-03-2007 03:35 PM |
| Left Hand Tap M8 | JKWidener | Machine Shop and Tool Talk | 4 | 12-14-2006 09:18 PM |
| Reid: Left vs: Right hand | Rich Hudak | Oil Field Engines | 1 | 11-23-2006 11:49 PM |
| Right or left hand rotation | Gene Fisher | Antique Gas Engine Discussion | 0 | 01-25-2005 07:27 PM |
