Which engines ran counterclockwise?
this thread has 45 replies and has been viewed 6209 times
Old 09-25-2004, 05:37:25 AM
PaulGray
Default Re: TRIVIA: which engines ran
Bessemer starting engine/compressor (crank from the back on flywheel). National transit Lil Hummer
Old 09-25-2004, 11:32:17 AM
Ken Majeski
Well.... I had a New Idea Vari Speed that ran backwards... I couldn't find a magneto that turned in the proper direction so I just changed the engine to match one I had...
Old 09-25-2004, 07:43:06 PM
The air-cooled starting engines on the IHC Titan and Mogul tractors.
Old 09-25-2004, 08:37:47 PM
NICK
The F&J farm pumper has already been mentioned twice but also their Multimotor and model J run CCW. Some engines have a cam where you can change the position of spark timing contact to run CW. The later radiator cooled engines were available that ran in either direction.
Cheers! NICK
Old 09-25-2004, 09:01:57 PM
ihorse
I think that Moline unitractors ran ccw, d,j,
Old 09-26-2004, 12:13:22 AM
roy
Chrysler 2 stroke industrial engines (used on tampers) culd be timed to run in either direction. The F-M rewind was also reversible This ia also how some golf carts and railroad maintenance jiggers changed direction. Slow the cengine almost to a stop then advance the timing far enough to cause the engine to kick back. Took some practice
Old 09-26-2004, 10:26:05 PM
Chester
WOOLSLEY WD2 ?
Old 12-20-2004, 12:25:36 AM
Skip Landis Skip Landis is offline
Default Re: Which engines ran counterclockwise?
the horrizontal new ways run backwards, but the verticals dont. skip in nw montana
Old 12-20-2004, 12:44:27 AM
Detroit Engine Works - both the Marine and Stationary engines could be run in either direction. The Galloway 5 HP could be reversed also. The REO cast iron 45 degree engines ran CCW, they took power off the cam - @1/2 speed. Some versions had a 4 to 1 reduction, and there were some put on Rotary Mowers that took power from the flywheel side.
Old 12-20-2004, 08:34:31 AM
Doug Kimball's Avatar
Images: 76
Dunn Motor Works 4-cycle marine
Old 12-23-2004, 02:18:56 PM
R Pope R Pope is offline
My Lister light plant made in 1929 runs "backwards". Field Marshall Series I and II did, too. The Series III had a countershaft in the trans. to get six speeds, and the engine was made to run the "right way." (Not that that stopped them from running the other way!)
Old 12-23-2004, 07:15:16 PM
Chuck
there is an engine made in kitchener ontario called a turk and i think it ran backwards.
gilsons can be made to run backwards to.
chuck
Old 12-23-2004, 09:27:13 PM
landlockedmarine landlockedmarine is offline
The Mercury Mk75 and Mk78 and Merc 700 engines made from 1957 to 1960 were not gear shifted outboard motors. They had a starter that would turn the engine the opposite way to obtain reverse. There was no neutral for these outboard engines. They were started in either direction. Oddly enough they made a left and right handed lower units for dual motor set up for counter rotating propellers. Counter rotating propellers would balance the motors when turning if the two motors rpms were not matched. If a boat were set up with two motors with the same rotation the boat would "drift" while turning. Weird.
Old 12-23-2004, 10:46:02 PM
Lloyd Osmun Lloyd Osmun is offline
Backus engine runs either way
Old 12-23-2004, 11:56:30 PM
John Davidson John Davidson is offline
eMail NOT Working
My ELI will run either direction without any adjustment. It is 2 cycle with piston contact low tension ignition. Always in time and always retarded. Makes spark after top dead center.
Old 03-20-2005, 05:01:53 PM
riklemmens
A Van Rennes kerosene marine engine runs CCW
Old 03-20-2005, 10:17:55 PM
Gary Pflum's Avatar
Gary Pflum Gary Pflum is offline
Any of the Waterloo style engines can be retimed to run "backwards"
Old 03-28-2005, 05:51:07 PM
Kyle McGee's Avatar
Kyle McGee Kyle McGee is offline
No one has mentioned Gilsons. My brother in law has one that will run either way depending on the set up. Haven't tried to run it backwards yet that is this springs project.
Old 03-29-2005, 01:23:35 AM
David Johnson David Johnson is offline
Lufkin L-795 engines were designed to run cw and ccw directions.
Old 03-31-2005, 02:31:46 PM
Forrest A's Avatar
Originally Posted by Craig Anderson
Aultman Taylor, Rumely B, E AND F.
Actually no, they run clockwise, as viewed from the flywheel side, all two cylinder Oilpull models past those listed ran CCW. John Deere two cylinders run CCW.
Forrest
Good Engines and Bad Engines Mark Thompson Steam Stationary Engines, Traction Engines, Steam Boats 75 11-27-2009 08:45:32 PM
clockwise or counterclockwise (spin or not to spin) HawaiianTim Generators & Motors General Discussion 18 10-02-2005 10:52:32 PM
