Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Antique Engine Photos
Twin cylinder Edwards low-tension engine
Here is an unusual engine sighted at a recent rally. It is a twin cylinder Edwards low-tension...
this thread has 18 replies and has been viewed 2136 times
Old 12-09-2001, 07:14 AM
Patrick M Livingstone
Default Twin cylinder Edwards low-tension engine
Here is an unusual engine sighted at a recent rally. It is a twin cylinder Edwards low-tension engine. It was very difficult to start but ran well. The twin ignitors are tripped internally by trips on top of the pistons!
Young Rally 2001
Old 08-15-2008, 07:06 AM
therubys6 therubys6 is offline
Default Re: Edwards
hi my nane is glen and the edwards shown was my dads, the wellknown Don ruby...unfortunaly dad past away in march 2008 i have got it going and have no problems starting or running. i am a member of the yackandanda club so every one should come to all rallys and see just nice they are.
thanks
glen
Old 08-15-2008, 10:23 AM
Elden DuRand's Avatar
Images: 6
Default Re: Edwards
Patrick:
The Edwards engines must be one of the more unusual "independently engineered" engines of which more than a handful were made.
I restored one for a friend a couple of years ago and documented the "unusualities" of the Edwards when I did the work. You can see it on my website.
Take care - Elden
http://www.oldengine.org/members/durand/
The Following User Says Thank You to Elden DuRand:
Old 08-15-2008, 07:50 PM
Default Re: Twin cylinder Edwards low-tension engine
yes it does seem to be unusual and its #402 so its a early one.i have a video on you tube. there are two on there. does anyone have any info including photo copyed papers and so on.
thanks
glen
Old 08-15-2008, 08:48 PM
hi i forgot to ask. how many drops of oil should i be useing and what grade oil.
thanks
glen
Old 08-15-2008, 08:52 PM
Images: 6
Glen:
Use just about any modern oil. I used 30W detergent and set the oilers to about six drops a minute. I was told they need to be run sloppy on oil because the big ends are lubed by the same drip oilers that do the bores and wrist pins.
Don't forget to keep the oil wells in the mains wet and give the governor and gears a squirt once in a while.
Take care - Elden
Old 08-16-2008, 08:55 AM
thanks and shall do do you no where i can get a copy of papers and info for it
thanks
glen
Old 08-16-2008, 12:10 PM
Images: 6
Glen:
You are welcome to copy any of the Edwards information off of my web page. All I ask is that, if you copy my photos and/or text, you credit me with them.
BTW, that is the extent of what I have on Edwards engines.
Take care - Elden
Old 08-16-2008, 07:48 PM
thanky you and i will do. as i can see you have put a lot of time into you edwards page and the ed its self.would you no about witch year my #402 is. i have a some papers but no date
in them is a paper which explains the different models...i noticed you pull start yours from behind ???i start mine from the front as there is no chance of getting hit by the strap (not yey anyway)
thanks
glen
Old 08-17-2008, 11:50 AM
Images: 6
Glen:
I thought about pulling the starting strap from the front but the gas tank, fuel line and float bowl are in the "line of fire" and I didn't want to damage 'em.
A good idea would be to wear a helmet and face mask when starting the beast.
Take care - Elden
Old 08-17-2008, 06:25 PM
sorry elden
i for got yours is a different model.do you no of any others in australia.have you seen mine on youtube as yet. runs a bit ruff on two pots but runs very smooth on one.thanks for the oil info as i have the drops on 4-5 now it makes things a bit messy but as you said it needs it .
have you any paper work you can copy???
thanks
glen
Old 08-18-2008, 11:26 AM
Images: 6
Glen:
I just looked and found the one uploaded by "pileofiron". If that's not the one, give me a link.
I can put you in contact with Frank, the owner of the Edwards I restored. He's got what you see on my site. Please P.M. me and I'll give you his email.
Take care - Elden
Old 08-18-2008, 06:20 PM
i think if you enter edwards twin cylinder in google you will find it. i dont no how to do the link.and thanks again
glen
Old 08-18-2008, 09:29 PM
Images: 6
Glen:
I found it! Thanks! That's a nice looking early ignitor Edwards. I don't feel so bad about the one I restored now. It runs like the one in the video.
I guess that when they are loaded they will settle down.
Take care - Elden
Old 08-19-2008, 02:47 AM
good stuff,dad has done a great job..they run rought but still sound good.maybe one day i will have all four modles.
now that would be nice.
i am also getting his #30 2hp james martin..and a 3hp tangy hot bulb type...
cant find much on these two either
untill next time
glen
Old 09-07-2008, 06:57 PM
does any one have or can tell me where to get new or good ignitor points that will fit an edwards twin cylinder please
thank you
glen
Old 09-07-2008, 09:20 PM
Images: 6
You can get ignitor points from several sources found here. One of them is Lee Pedersen.
Take care - Elden
Old 09-12-2008, 06:21 AM
Ray Freeman Ray Freeman is offline
Originally Posted by therubys6 View Post
sorry elden
thanks
glen
One of the blokes in our club here in Perth has one in dismantled condition but I don't know what model it is. I can likely put you in touch if it would be any help.
Old 09-12-2008, 06:27 AM
hi and yes please any info is great.my dad hade spoken to some one in wa but thats all i no
thank you
glen
Nordberg twin cylinder steam engine - Info Wanted Anonymous Stationary Steam & Traction Engines 4 12-19-2008 10:52 PM
Buzz Coil Wiring for a 2 Cylinder Edwards Engine? Larry K Antique Gas Engine Discussion 15 10-31-2007 12:01 PM
Stover Air-Cooled Twin Cylinder Engine Picture Larry K Small Air Cooled Gasoline Engines 0 11-01-2005 06:43 PM
Edwards two cylinder dougk Antique Engine Archives 0 09-09-2001 12:19 PM
Anyone own an Edwards Two cylinder? Norm Antique Engine Archives 3 06-12-2001 04:50 PM
