Franklin Valveless piping
Does anyone know how to work the gas intake on a 25 HP Franklin Valveless? Mine has similar piping...
this thread has 0 replies and has been viewed 614 times
Old 08-03-2004, 07:02 PM
Roy Pasini
Default Franklin Valveless piping
Does anyone know how to work the gas intake on a 25 HP Franklin Valveless? Mine has similar piping to others pictured on the internet. There is a gas valve before the flyball governor, then the piping branches off to upper and lower valves, both of which seem to go into the cylinder. The lower valve is piped into a fitting that seems to have a needle valve in it. To compound matters, there seems to be a chamber under the cylinder in which there seems to be an air intake controlled by about a 3" wheel. If anybody has any experience in running these engines, your help would be greatly appreciated. My engine is in great shape, and should run, if only I know the secrets of its gas system. Thanks!
25 H.P. Franklin Valveless Fred Van Hook Oil Field Engines 0 09-02-2007 09:17 PM
franklin valveless 25 hp tim rostar Antique Engine Archives 0 10-28-2003 05:38 PM
franklin valveless tim rostar Antique Engine Archives 0 10-09-2003 09:21 PM
Franklin Valveless D.J Baisch Antique Engine Archives 0 01-01-2002 10:24 PM
FRANKLIN VALVELESS BACKFIRING DICK LEPLEY Antique Engine Archives 2 11-24-2001 06:07 PM
