| Antique Engine Archives All archived posts from 1999 to 2004 when SmokStak was on EnginAds. This is a read-only board. |
Piston ringsGetting back to Engines. How bout some input on this question . What will provide better sealing in...this thread has 3 replies and has been viewed 759 times
Getting back to Engines. How bout some input on this question . What will provide better sealing in a slightly worn bore , a piston with 2 rings in each groove or a piston with a single ring in each groove ?
All comments appreciated ED |
I would say two rings in each groove, with two you can stagger the gaps thus getting a better seal. I have a six horse Fairbanks Morse "H" that had been rebuilt sometime in the past. The ring grooves were widened and two 1/4 inch rings are in each groove. The compression is very good. Hope this helps a little.
Hi ED For what it's worth I think 2 rings stagered works best. Some people on Smokestak (I Think) Said they will work there way around till the ends get lined up with each other. My 2 HP Witte has 2 in each Groove and it runs well. Good Luck Have you tried the hardner in the paint Yet? Been waiting to hear how it worked out. I have a Pump to paint soon. Tom Jr.
I agree with Joe & Tom, I have used double rings on many of my engines and I think it works better than using just one, especially on wide grooved pistons.
| Piston Ring Material for Custom Machined Piston Rings. | Uncle Old Iron | Antique Gas Engine Discussion | 3 | 06-24-2007 01:50 AM |
| Piston Rings | Lonnie Grissom | Antique Gas Engine Discussion | 3 | 03-16-2005 06:25 PM |
| piston rings | brickman | Antique Engine Archives | 1 | 02-07-2004 11:14 AM |
| New Piston rings ! | Jack Hallaran | Antique Engine Archives | 3 | 05-23-2003 01:07 PM |
| Piston rings | Marty | Antique Engine Archives | 11 | 01-29-2003 08:43 PM |
