Cleaning up Brass castings
I have a 2 inch Atlas brass piston pump which I'd like to use on my Oil Field engine for coolant...
this thread has 11 replies and has been viewed 1540 times
Old 08-24-2004, 04:01 PM
Doug Brookens
Default Cleaning up Brass castings
I have a 2 inch Atlas brass piston pump which I'd like to use on my Oil Field engine for coolant circulation.
It's been in use a long time and is covered with layers of of oil and oxidation.
How can I clean this piece down to the bright brass?
Thanks, Doug is WA
Old 08-24-2004, 04:37 PM
murrayc
Default Re: Cleaning up Brass castings
elbow grease
Old 08-24-2004, 05:13 PM
Chuck Martin
Degrease it with brake cleaner and then soak it in a strong solution of citric acid.
Old 08-24-2004, 06:41 PM
Franz
The same electrolosys process used to remove rust from iron will get you down to brass. Shiney will require manual labor.
Old 08-24-2004, 11:15 PM
John Davidson
Oven cleaner works good. Buy it the grocery store. Spray it on, wait a little while and hose it off. If thick grease, might take a second time.
Old 08-25-2004, 08:42 AM
Len Zook
Simple Green left to soak does a good job and isnt as caustic as oven cleaner. Smells good too. My buddy and I use it to clean just about everything including our hands. It did wonders removing grease from my cushman. The maytag is getting a dose of it real soon.
Giant has a brass polish in the cleaning isle but I cannot remember the name. It removes tarnish like crazy but will not polish out heavy scratches. It is in a brown bottle and has ammonia in it.
Len
Old 08-25-2004, 10:42 PM
Fred Van Hook
At the grocery store or drug store you can find Zud. Cheap and works great. If money is no object find on the internet "FLITZ". It's another great product but a bit pricey. LOL Fred
Old 08-26-2004, 11:35 AM
Bob Johnson
I use plain old ketchup to start with to remove the crud on brass. Flitz is a great polish for brass
Bob out west on the high desert
Old 08-26-2004, 05:10 PM
Kid Dynamo
Making sure not to damage any seals that might be intolerent, I use paint thinner to clean brass items. When the grease is all removed, I use hot water and liquid dishwashing soap and stiff plastic bristle brushes. I stay clear of wire brushes, scotchbrite, or anything that will scratch the surface. I have Flitz, Brasso, and other brass polishes, but seldom use them.
The idea is to keep the original patina that formed on the parts at manufacture. Scratching, scuffing, and polishing/buffing permanently removes this original finish.
I recently bought a beautiful pair of large, swingtop oilers that the seller was proudly touting his buffing job. He must have spent hours at a buffing wheel but as far as I'm concerned, he lowered the value. People see them and ooh and aah, but no good antique appraiser or museum curator will be so taken.
Buffed out parts are the preference of many people, for sure, but watch the "Antiques Roadshow" on PBS and you'll get the drift about original finishes and value. No doubt, all those wonderful antiques that had their original finish lost through "restoration" enjoyed a brief time where the "new" finish was admired by most onlookers. Ultimately, however, true value of original finish and patina will be recognized, I will bet.
Now, fire away !!
Old 05-10-2005, 01:23 PM
Ray Cardoza's Avatar
Braso and lots of elbow grease of course do this after grease removal
Old 05-10-2005, 05:17 PM
Robt.'s Avatar
Robt. Robt. is offline
Quickest way I have seen to remove heavy oxidization is soda blasting. Walnut shell or plastic bead would probably work as well, but you'd have to watch the pressure or the surface may end up stippled as it does when using glass beads. Soda leaves it clean and ready for buffing/polishing. Takes off dirt and paint well too!
Old 05-10-2005, 05:22 PM
Robt.'s Avatar
Forgot to mention: if you have rough or damaged castings you want to smooth down before polishing, the Walter "Qwik-step"(sp?) abrasive pads on a 5" angle grinder are great. Come in three grits and they work FAST! Velcro backed so changes are quick too.
Cleaning a Brass Oiler Lonnie Grissom Antique Gas Engine Discussion 10 11-09-2009 12:19 AM
Cleaning dirty Brass GarysToys Antique Gas Engine Discussion 11 02-16-2007 12:00 AM
Brass Polishing and Cleaning bocephus_k6 Paint Shop 11 10-18-2006 01:38 AM
Brass cleaning solution Pat Barret Antique Engine Archives 11 01-29-2004 10:33 PM
Cleaning Brass Denny Foster Antique Engine Archives 9 08-11-2000 12:31 PM
