leaky mccormick 10-20 head
We got a parts tractor 10-20 that we got running. Well one of the problems it has is that there is...
this thread has 2 replies and has been viewed 651 times
Old 09-06-2004, 11:59 PM
cgbusch
Default leaky mccormick 10-20 head
We got a parts tractor 10-20 that we got running. Well one of the problems it has is that there is a hole in the head behind the exhaust valve that goes into the water jacket. My brother stick welded it which patched the hole. However, there is a slight water leak. Everytime we try to patch it more, it seems the water leak does not go away. Our theory is that the different metals cool at a different rate and then crack. Could we braze over the area to seal any cracks? Will the braze melt from the exhaust?
I've read an article on rebuilding a model T or A engine where they took the head and sealed the water jackets with really milky expoxy. They taped offed the water parts and filled it up with expoxy let it sit for a bit and drained the rest. Does any know what kind of expoxy it is?
Old 09-07-2004, 12:06 AM
Junkologist
Default Re: leaky mccormick 10-20 head
I don't know anything about the epoxy fix, but the exhaust tenperature is not high enough to melt brass, if you brazed the hole shut. The cylinder head would have to get cherry red in order to melt the brazed repair.
Mike
Old 09-07-2004, 12:33 AM
Chuck Rich
In either welding or brazzing You should pull the head and heat it cociderably so the welded or brazzed area can cool with the rest of the part. This is the case with all cast iron repair.
Chuck
Leaky fuel tank Dslsmoke Onan Generators 9 10-23-2007 10:07 PM
Help! Leaky CheckValve on IHC-M RangerBob Antique Gas Engine Discussion 7 11-17-2006 07:14 PM
Plugging leaky tubes Dale Noel Stationary Steam & Traction Engines 29 04-19-2006 11:35 AM
Need Help with Leaky Zenith Dale Breault Onan Generators 3 08-12-2003 12:42 PM
Leaky Deere Mike in SE PA Antique Engine Archives 6 09-02-2002 12:51 PM
[IMG] code is Off
