Power Products 2 cycle mods
I have 2 Power Products engines . I need to run one of them backwards . Can this be done and get...
this thread has 2 replies and has been viewed 656 times
Old 09-08-2004, 06:28 PM
Brian Thomas
Default 2 cycle mods
I have 2 Power Products engines . I need to run one of them backwards . Can this be done and get the same power output as the other ? Thanks Brian
Old 09-08-2004, 09:51 PM
J.B. Castagnos
Default Re: 2 cycle mods
I'm not familiar with your engine but most 2 cycles will run either way with no problem. The exception would be an engine with a rotary valve on the crank. Your ignition will have to be retimed, if it has a removable cam it would be easy, if not it could get involved.
Old 09-11-2004, 04:36 AM
Andrew Mackey
P.P. engine will not make power if run in reverse - ignition timing will be way retarded and engine will run hot - if at all. To run reversed, both the ignition cam and the flywheel will have to be re-keyed for the proper timing. If the factory keyway is set at top center, simply inverting the timing cam will set the points, however the flywheel will still have to be re-keyed to pass the magneto at the proper time. Converting these engines to battery and coil is not practical, as the points are normally closed (coil will overheat). Some of the Model 1000 engines will run reversed - if the magneto addembly can be retarded enough on the block. (normal directionaly retarded will be advanced on reverse run engine) Andrew
Power Products Governor Jeff Conner Small Air Cooled Gasoline Engines 2 06-06-2008 04:31 PM
Power products John Rolli Small Air Cooled Gasoline Engines 8 12-25-2007 09:57 PM
power products / hiller ben john Antique Engine Archives 2 11-02-2004 07:31 PM
Power Products Engines Brian Thomas Small Air Cooled Gasoline Engines 2 06-02-2004 11:25 PM
Power Products (Tecumseh) Harry Antique Engine Archives 0 05-23-2001 12:42 AM
